GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Fix it quickly as possible as all of you can
Ricevuto aggiornamenti ieri sera. Funziona tutto bene! Grazie
Anonymous
Not applicable
Thanks a lot for fixing the issue so quick! My dongle updated itself yesterday without any hassle and it works again. Pls note I performed a factory reset  on  my Chromecast gen2 before the fix was rolled out. I solved the issue by setting the system date of my Andoid tablet to March 5 and reinstalled the device. Of course, it did not stream anything but it could boot up again and connect to Google's server. When the fix was sent to it remotely, it had no issues with the update. thanks a lot Google, great job!
Hurry yo ahh up, bro. I neeeed to watch ma westerns with my wiiiffee 💔💔💔
Só podemos ficar esperando, muito ruim está situação.
Anonymous
Not applicable
Any news? My chromecast is out of service yet
Hola, espero que lo arreglen lo antes posible. Yo ya llevo más de una semana sin poderlo utilizar.
Cómo me avisarán si lo puedo usar, lo reinicie de fábrica 😭😭😭
Hey Google. Last week I met a problem with my chromecast 2nd gen. The device could not be verified. Pushing the reset button for 12 secs didn't bring solution. Please help. Many thx! Philip.
Anonymous
Not applicable
dear Google, the update works fine! Both my Chromecasts 2nd gen are up and running. However, it’s a pitty I already bought a new one cause I thought mine had definetly broken down!
Please tell us, how we can find out, if an update was done on our devices.
Where to find out, which firmware should be installed.
Yey! I started workin again today .. good job! // google audio cast 2nd edition, region: Europe
Anonymous
Not applicable
Still not working. When I noticed that my Chromecast2 wasn't working, I obviously did a factory reset. I am currently able to go through all the process of setting it up with my Google Home App, but it fails to connect to the common wifi.
Any advice on how or when this will work again would be much appreciated!
Hello I just put my phone back to 28 february and go Home application and configure my chromecast. It works ! Thank's to the contributors !
jpdlx
hello did the same as you on both my chromecast, it was working but now since yesterday it doesn't work anymore (picture image chromecast blinking), it is the same for you ?
Hi Google team,
I have the 2nd gen Chromecast device and got it factory reset while facing it initial outage. Now it's been a long week, when can I see it resolved, my kids are after me and making my life very tough & hard. Please do fix this asap. It will be much appreciated.
Thank you for resolving this hard to resolve issue for decommissioned devices. It would have been nice not to reach this point in the first place, but hey people make mistakes 🤷
I am grateful for your quick (relatively) response to the issue and the automated resolution for it, without any user action involved.
Why it take all this time!!
Please share a solution asap to re-setup the device after initial factory reset.
Anonymous
Not applicable
I had reset the chromecast to factory settings. Google Home could no longer find the chromecast. I set my phone to March 8. Then added the chromecast again with Home. The chromecast automatically updated. After the update everything works properly again : ) Set the phone back to the current date
jpdlx
hello did the same , it was working but now since yesterday it doesn't work anymore (picture image chromecast blinking), it is the same for you ?
No wonder.. FYI, I've already troubleshooting with multiple methods.. remove the devices, add on again, unpluggedd replugged.. almost a week now.. how long we still need to wait?
Somos una pareja de ancianos y la tv es de vital importancia.
Volvi configurarlo de fábrica y confio me avisen urgentemente y di es posible a mi correo #
While you broke our devices we are still paying streaming services. It's already 1 week waiting. Faster thanks.
for people who did a factory reset, there is still no information when you will solve the problem !!! please make an annoncement
Titta
I was able to solve today with this procedure.
- set the date on your phone to 1st March 2025
- Use the App Google Home to connect the Chromecast device (this way works)
- follow the instructions for connection and setup
- after the setup the device will start an update and now works as before
Hope it helps
jpdlx
hello did the same it was working but now since yesterday it doesn't work anymore (picture image chromecast blinking), it is the same for you ?
Vilas3287
Its working for me!
Il dispositivo Letto potrebbe essere configurato, ma non è stato possibile stabilire una comunicazione dal tuo iPhone. Assicurati di avere attivato l'accesso alla rete locale nelle impostazioni sulla privacy del dispositivo iPhone, quindi riprova.
questo é quello che mi viene detto quando provo a connetterlo
hey, I did fabric reset mine chromecast so he couldn't connect with Wi-Fi, what i did i change date on my telefon for 8.03.2025 ( any date before 9.03.2025 should work) and than he allowed me to provide configuration, connected with internet and automatically downloaded a new actualization..its working now 🙂 i change date on my phone back again and its just working perfectly, greetings Sylwia
jpdlx
hello did the same it was working but  it doesn't work anymore (picture image chromecast blinking), it is the same for you ?
Team, what kind of support is this. How many days will you all take. I have reset both my Devices.
Finally.. I changed the date on my phone to 4th march and connected successfully.. Troubleshooting by myself after how many days waiting..
I had made a reset. What is the solution now? 😔
can you informed what you mean by "Your device must be connected to receive the update" do you mean that you should connect to power supply ?
Salve volevo sapere ma il chromecast deve essere attaccato al TV anche spento?
A lot of thanks to google for the quick fix of the chromecast v2 certificate issue!!!!!
seriously we’ve been without streaming for a week on our 3 TVs please fix ASAP
Hi @GoogleNestTeam  any further update on fix or ETA for fix
Hay que dejar el TV encendido con chromecast conectado? O solo el chromecast conectado recibe la actualización,no puedo emparejar con el móvil,no sé que pasa,este es mi correo #
