GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Ok estou com quase 30 dias co problemas... Quanto tempo mais teremos que esperar? Porque não fazem um recall e nos dão outro que esteja funcionando no lugar?
Wow!! Finally my Chromecast is updated and working like before.
I have done a factory rest couldn,t connect. Please fix ASAP.
If you had acted faster in informing people then people might not have factory reset there devices  like me,mines been down now since last Sunday without a fix only got informed by yourselves Thursday by email which is pathetic!! I hope your going to replace the ones that have been factory reset if you can't find a fix???
Жду............
Il mio Chromecast continua a non collegarsi al telefono...
Mi dà come risposta "impossibile collegarsi al dispositivo"   V7D7. Spero riusciate a risolvere in fretta questo problema, rischiate di perdere credibilità e utenti...
Anonymous
Not applicable
Lo pude restablecer de fabrica , pero sigue sin funcionar .... es correcto esto ???
Still not able to connect did factory restart
So any fix uppdate for us that performed a factory reset yet??
Gracias. Tengo dos dispositivos. El que no reinicié se solucionó hace 3 dias y anoche el otro
Just sharing in case it helps with the solution for those that factory reset - the Chromecast does at least go to the set up and my phone can recognize it. But it still says that it can't communicate with the Chromecast so set up can't be completed.
Anonymous
Not applicable
Thanx, works OK now.
Propose to make a deep root cause analysis to prevent this to happen once again..
Is there any update for Chromecast 2nd generation because mine is still not working?
Now that the fix is rolling out, what are the steps for those of us that followed standard troubleshooting procedure by doing a factory reset before Google told everyone that they shouldn't do that?
Update for those of us who for the factory reset?
Buongiorno... quando si prevede la risoluzione del problema per chi ha resettato il dispositivo? Ormai è una settimana che non va
Quirino
Infatti il mio ripristinato più volte è manco va non lo riconosce proprio più non lo associa
Still waiting for a solutions after the factory reset.
Thank you, Google guru’s, my Chromcast 2nd generation works again, even after the factory reset. Right on time for Formula 1 racing season!
I reset my chromecast to factory defaults, and I still can't reconfigure it
Same 😤👍😤 even with changing date manually
I reset my chromecast to factory defaults, and I still can't reconfigure it. Help me please
What is a few days? Config is still not working in Denmark
Mar 15th. Deep south. Tornadic activity EVERYWHERE. No internet is not helpful
"If"?
When do you expect to solve the problem?
Ik had mijn chromecast 2 al gereset voordat ik het probleem vernam.
Hoe kan ik op de hoogte worden gebracht wanneer het gefikst is?
Vriendelijke groet Leen
Solution pour tous ceux qui ont fait tout comme moi un reset de leur chromecast de 2ème génération : il suffit de changer la date de son smartphone avant la date de la panne du 9 mars 2025. Cela a fonctionné pour moi en désactivant le fuseau horaire et date automatique dans les paramètres systèmes Android. Puis j'ai ouvert l'application Home depuis mon smartphone > ajouter un appareil > il m'a proposé de configurer la chromecast détecté sans erreur > j'ai configuré le Wi-Fi de la chromecast et j'ai débranché la chromecast puis rebrancher et maintenant cela fonctionne à nouveau. Cyrille
AASARMADI
Unfortunately I am not familiar with these issues at all. Please tell me how to reset my phone to March 7th?
I miei Chrome cast hanno ripreso a funzionare
It’s working again. I did factory reset the device and this did the trick: set you phone to 7 march, setup/connect the chromecast and it will do an update. After the update it did take about 10 minutes for it to really be up and running again correctly but it works! After this put your phone on the correct date again.
AASARMADI
Via setting you go to set time. There you turn off the automatic time setting. In the agenda you change the date.
I am a computer illiterate so ehen i can this, everybody is sble to do so
Yes, localize the configuration of Day, month and year and put it on 6-mar-2025. After this, reinstall your chrome cast.
Anonymous
Not applicable
How does i do this
It’s taking a long time!! When this will be resolved
Ho modificato la data al 03/03 sul telefono, così Chromecast ha fatto l'aggiornamento. Finalmente ha ripreso a funzionare.
Ricordati che terminata la configurazione su Home e l'aggiornamento, devi reimpostare la data odierna sul tuo telefono, affinché Chromecast si colleghi al telefono stesso.
Any idea on the time it will take?
Finally am back! Kudos Nest Team!!
Uma semana é tempo demais para corrigir!
Eu redefini de fábrica, nunca iria imaginar que era um problema mundial, e continuo sem me conectar ao chromecast.
Agilizem isso!
