Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-15-2025 10:24 AM
eu já havia voltado para aa configurações de fabrica quando fiquei sabendo hoje desse problema. Por favor me envie as instruções para poder resolver o problema. Obrigado
03-15-2025 10:25 AM
Second day and still nothing
03-15-2025 10:25 AM
Quiten de la ayuda la parte que dice que reestablecer el dispositivo a la configuración de fabrica puede solucionar problemas de conexión de esa manera nadie se hubiera puesto a recetear nada
03-15-2025 10:32 AM
Yo reinicie el dispositivo, cuando estará lista una solución 😭😭😭 extraño mi dispositivo
03-15-2025 10:35 AM
Finally got mine working again today.
I had factory reset my Chromecast, this didn't help as I couldn't reconnect..
Changed mobile phone date back to 1st Marchand re-ran setup from Google hone, Chromecazt now connected.
Setup downloaded an update for Chromecast, this appears to have fixed thr bug!
03-15-2025 10:35 AM
Thank you so much for keeping us up to date; both with info and for our poor little old devices.
I had factory reset my Chromecast. I set the date on my phone a month back and got the Chromecast back online and the update started immediately. Works great now, thanks again!
03-15-2025 10:36 AM
Do you have an updte on your time frame? By now my streaming apps aren’t even seeeing the google chrome cast audio anymore nd google home still says it is off line.
03-15-2025 10:38 AM
For those who reset their device to factory settings, simply disable automatic time and date settings on your phone. Change the date a few days before March 9th, then start the reconfigure from the google Home app...that's all..!!
03-15-2025 10:37 AM
Quando irá resolver o problema não consigo acessar pra por a internet aparece q não foi possível autenticar o Chromecast
03-15-2025 10:42 AM
Io purtroppo ho effettuato il ripristino ieri 14 marzo e ad oggi non sono ancora riuscito a collegare chromecast. Cosa si può fare ? Grazie e saluti
03-15-2025 10:43 AM
Hi everyone, Just wanted to share my experience. I performed a factory reset on my device, which Google had advised against. After the reset, I rolled back the date on my phone, and the connection was successful. Following this, there was a firmware update from Google. Now, everything works fine—I’m able to cast all OTT platforms and YouTube without any issues.
Hope this helps!
03-15-2025 10:44 AM
During setup Google Home cannot authenticate my Chromecast device. Is it the current problem experienced by others? Thanks in advance!
03-15-2025 11:50 AM
Set your Phone date back to March 5.
03-15-2025 10:47 AM
Como será? Estou a 1 semana sem a conexão
03-15-2025 10:48 AM
Hi, I performed a factory reset during initial troubleshooting, the issue is still there. Please give me an update as soon as possible. Thanks. Yuri
03-15-2025 10:50 AM
What is the expected date for the fix, it's been a week now
03-15-2025 10:54 AM
Bonjour,
Suite aux différents commentaires sur j'ai lu, j'ai pu réparer ma Chromecast.
Si vous avez remis l'appareil à l'état usine comme moi, Voici la procédure à suivre :
1) changer la date de votre smartphone au 8 mars 2025 via "paramètre/paramètre supplémentaire/date et heure"
2) ouvrez google Home et ajouter un appareil Chromecast (la configuration de l'appareil, la connexion au wifi et les remises à jour vont pouvoir se faire)
3) à la fin de la configuration j'ai eu un message me disant que ce n'est pas encore possible de terminer la mise à jour entièrement pour l'instant, appuyez sur le bouton "quitter la configuration" et fermez google home.
4) remetez la date du jour sur votre smartphone
5) redémarrer google home : la Chromecast est à nouveau fonctionnel !
03-15-2025 11:47 AM
tried this multiple x's....NOT WORKING!!!!
03-15-2025 11:00 AM
I had to change my router and wireless SSID as part of a wireless infra upgrade. So my Google Nest Mini became unresponsive due to the network change. So I had to perform a factory reset as part of connecting to the new SSID/wireless network and now its still unresponsive after setting up in Google Home app.
Is this because of the issue noted in this thread? If so, when can we expect a workaround for folks in my situation?
03-15-2025 11:04 AM
Por favor, avísenos cuando esté solucionado para restablecer los valores de fábrica. Gracias.
03-15-2025 11:04 AM
Qui factory reset.
Ho cambiato la data del mio smartphone al 15 febbraio e poi provato a riconfigurare il Chromecast. Ebbene, ci sono riuscita! Dopodiché il Chromecast si è aggiornato e ho potuto usarlo con la data corretta.
03-15-2025 11:05 AM
My chromecast audio started working again today.
THANKS for fixing this.
03-15-2025 11:09 AM
Work for me too. Changed the date to 28th of February and update after that.
03-15-2025 11:10 AM
Hi Team,
please do assist to fix the one with factory reset
03-15-2025 11:22 AM
Would've helped if you had made that **bleep** message come up on the screen before I reset my device multiple times.
03-15-2025 12:01 PM
Same here
03-15-2025 11:24 AM
I still can’t connect with cromecast .
03-15-2025 11:27 AM
me neither
03-15-2025 11:25 AM
Hola. De Cuánto es la demora. Hace 2 semanas que no puedo conectar mi Chromecast..
03-15-2025 11:28 AM
Fix it. Fix it. Fix it. Fix it.
03-15-2025 11:33 AM
I did the fix for mine.and it for all the way to the end and got the attached message. I didn't exit setup yet so what do I do?
03-15-2025 11:33 AM
I had already done the factory reset here's how I fixed my chromcast,
(Andriod) settings - general - date time- turn off auto date/time setting, manually set date to MARCH 8,2025 then I was able to connect it to my WiFi, let it sit over night, next morning there it was ready to use, works perfectly again, you can turn your auto date setting on again as soon as your chromecast is connected to your wifi
03-15-2025 11:39 AM
Please help me chromecast don't worked
03-15-2025 11:39 AM
I can’t connect to wi-fi
03-15-2025 11:39 AM
When do you will fix problem with chromecast that were factory reset?
03-15-2025 11:41 AM
Ho fatto il reset di fabbrica.. pd..
Cosa devo fare ora? Ancora nulla?
03-15-2025 11:42 AM
Uno de los Chromecast ya me ha vuelto a funcionar, pero otro no, espero puedan solucionar la incidencia en todos
03-15-2025 11:44 AM
Please for how long this will take??
03-15-2025 11:48 AM
I did what someone said here earlier: set the date of my Phone back to March 5. I had reset my chromecast to factoren settings. Now Google could not find the chromecast and so i could not make an setups again.
But with the date on March 5, in no time the chromecast was found. Had only to rename it. Im not sure about the update...but so far i can stream again 😃👍
03-15-2025 11:50 AM
Waitin for al solution after a factory reset.
Thank you
