GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,136 REPLIES 16,136
Good afternoon.
I'm so sorry to bother you. But I do the factory reset to settings and can't use it.
Could you please help me?
  • Kind regards, Ivan
Hola, yo reinicie el equipo....desde donde podré ver los pasos para su instalación?
Still not working sunday 16th March
I did factory reset the Chromecast (several times), as this was advised on the other troubleshoot pages. I was not able to finish the installation process. Will the Chromecast still receive the required update?
I did a factory reset. Please help. Thank you for your cooperation.
Please fix this issue fastly
Anonymous
Not applicable
Eagerly waiting for Chromecast 2nd Gen fix
Good afternoon.
I have model NC2 6A5... It recognizes Chromecast 3674, but it won't connect to the device.
I performed a factory reset. The "do not touch" warning arrived late... I hope it gets fixed soon. If you could please let me know at my email #
Best regards, Ivan
Sigue el mismo problema al intentar conectar el móvil y la TV mediante chromecast, me reconoce el  chromecast  en el home pero al intentar conectarlo en HOME me dice: " NO SE HA PODIDO  AUTENTICAR TU CHROMECAST"
It sônr let me cast to tv
SherriR
Cant cast tv
I factory reset my device. Still waiting for a fix for this
I hope this helps ..I followed advice from previous community member
I had already factory reset my chrome before being warned not to .
So this is what I did ...
I changed date on my android phone to 7th March .
I searched for cast device through home again and it connected to it easily again.
Had a little weird back and forth where it said it hadn't connected yet it had on the TV .
The Chromecast started an update which also stopped and started but I let it do it's thing and it completed and restarted itself.
I did a hard reset/reboot on my phone (you know,where you hold the on/off button for ages and then reset)
I set the time and date back to automatic in settings on my phone.
This seems to have fixed the cast problems and am very happy to have my chrome cast back again ,I didn't know how much I would miss it .
Hope this helps
Palhaçada isso quero o meu Chromecast de voltaaaaa já faz 1 semana q eu tô sem assistir tv por conta disso,arrumem logo isso.
Did the factory reset before you told us not to. Still not able to connect. Will you tell us if it's unfixable and just replace our devices? Pretty sick of the permanent hopeful limbo!
Mi chromecast sigue sin funcionar y lo restauré antes de saber que no debía hacerlo! Me ayudan por favor!
Still waiting on a solution for those who logically performed a factory reset. Please fix this.
Hi, I’m still unable to use my Chromecast. Is the rollout complete? Also, the problem causes the Chromecast to not connect so how can I receive the update? Thanks for your help
Yo lo reinicie porque no sabía de esto. Cuando tengan la,solución la necesito
I followed some of the comments below and changed the date of my phone to March 1st, ran the set up and it went through. Then reverted the time on the phone again after set up was complete and was able to cast just fine.
Eu reconfigurei para configuração o inicial e agora diz que não é possível conectar com o Chromecast..o que eu faço estou a quase 1 mês sem Chromecast..
Anonymous
Not applicable
Ho ripristinato i dati di fabbrica e non funziona.
Have two devices, did factory reset on one.  Fix available yet?
I’m unable to re-add the device as a new chromecast. Home app doesn’t seem to recognize it.
Please I need help to setup my market place
For all who performed factory reset already:
  • change date settings on your smartphone to manual
  • set Date/time and set current date 8 march 2025
then you should be able to connect to chromecast and perform initial setup. As soon network settings are done, first thing chromecast does is to get an update, and your problem solved...
PS credits to Britt0415, it was his/hers idea (worked for me).
U have wasted alit of my time and I even bought a new tv box.thats 😭 and we don't expect this from google
Todavía sigue el problema, cuando se acomodará?
Hola aún se encuentran solucionando el problema para los dispositivos que se restablecieron de fabrica?
Still getting the error that it’s connected but to enable the local network, which is enabled. Guess I’m just screwed?
Any more uppdates?
Hoy se cumplen 8 días y el aparato aún no funciona....., que pasa?, cuanto más van a tardar en solucionar el problema?
Still no resolution for those of us who tried to troubleshoot? 😅
I already performed a factory reset. When will I be able to connect my chromecast again to my device? It’s been over a week now and I still can’t stream..
Let me know as soon as you have a solution
Problema técnico: a dias que o Google Home não conecta vídeos à TV. Tentei diversos recursos - conforme orientações da Google; porém sem êxito.
Por gentileza e se possível, quero que a questão seja solucionada; tendo em vista que o aparelho torna-se obsoleto.
Muito Obrigado!
Atenciosamente.
*tentei diversos recursos
