GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
Horizont
Auf den vorhanden Gerät nach ein Werksreset des Chromecast 2 das Datum auf den 8 März zurück setzen von wo aus es eingerichtet wird .
Es wird wieder in der Home App angezeigt, vorerst ohne Funktion,  nun ist es zumindestens mit den W-Lan verbunden, hoffentlich kommt das versproche Update bald .
Fonti
Cuando se Preve twnerlo solucionado?
Gianlaz
Grazie per la notifica anche se tardiva. Attendiamo un urgente risoluzione del problema, nel 2025 non è ammissibile che passino giorni per avere una riaposta ed una soluzione. Spero che la prossima notifica sia in tempo reale. Un caro saluto
8523010476
I am unable to utilise my chrome cast ,Please do it need full ASAP.
Rjt
Saw this in an post but can’t find it anymore.
I did an hard reset of the chromecast and couldn’t reconnect with wifi. Found The following workaround on here.
Set The date on your device to before the malfunction (before march 8).
return to connecting The chromecast.
See, its connected to WiFi.
Somasa01
Hola, yo lo restauré de fábrica y no me funciona. Saben que podemos hacer?
AgathaSm
Qual tempo de reparo
Knoerens
What plans are there for compensation?
Waxwingsmedia
IF YOU ALREADY FACTORY RESET YOUR DEVICE YOU CAN SET IT UP AND CONNECT IT TO YOUR WIFI AGAIN BY CHANGING THE DATE AND TIME IN YOUR PHONE TO MARCH 5th 2025 BEFORE INITIATING THE SETUP PROCESS. THIS WILL UNDO THE FACTORY RESET BUT THE DEVICE STILL WONT WORK UNTIL GOOGLE PUTS OUT AN UPDATE.
Funktioniert bei mir leider nicht!!
yeltommo
I can't even find my last reply. Anyway, I'm back to where I was. It seems that everything went fine. I see my CCA in devices, and it's not grayed out or described as offline, but I when I tap on it, it says "Not Available. Can't See Living Room Speaker on this WiFi network. Check that it's online and that your phone is on the same WiFi network." There's only one network that my phone and CCA can connect to, so being on different networks can't be the issue. But how am I supposed to confirm that my CCA is connected to wifi (which is apparently what I need to get the update) when I'm getting this "Not Available" message?
Poogirl
When will my chromecast work ? My phone apps aee not casting to my TV, what happened please
Coenf
Information on how te re-setup the device would be appreciated!
Mikael1
Hi,  Please also adjust the possibility to group wireless loud speakers via chrome cast, google home.
This feature has stopped working for Sony SRS-x99 and SRS - x88 since 2 months. This is very annoying.
Br
Mikael
Brio
Jeu,
I have already reset my device, what are the instructions to set it back  and receive the up date ?
NABOR1
Ded not open my crome cast I reset also but not open...
NABOR1
How to open my crome cast
pasqualinomare
thank you, I already did a reset ..waiting for instructions. Best
JackPe
Already did factory reset the device of course. I think it's the last resort, technical trained people will do, if nothing works and everything else has been checked. Hope to receive proper instructions soon! Good luck with resolving this issue!
meetarpit
I have factory reset the device since there was no response from the support team.
Mel11
Not good enough! Fix it asap!! I cannot watch any streaming without it
VolkerHerd
Wie und wann kommt die Lösung. Natürlich habe ich wie Beschrieben das Gerät zurückgesetzt als es sich nicht mehr verbunden hat.
Mel11
You’re a multi million dollar company and your products go down. Shame on you. We require compensation
Justvibeevents
I did a factory reset before I saw this message and now my chrome cast does not even let me connect to my home app when setting up z, to make the phone even. It’s shows chromecast 5662 on screen and on my phone when searching it on WiFi to set up says chromecast5562.b
yeltommo
How do I see the **bleep**ing most recent replies without tapping "Load more replies" until my finger falls off?
JeanBiance
Its working for me again !! Lets gooo
Nice to hear. What are the steps you followed? Could you please share it?
I just waited, one started to work two days ago and the audio came back today!
Yesterday both chromecast was back in the Home app. Did'nt do anyting.
Same here!
Deano24492
This needs fixing ASAP, if we're still using 2nd gen devices, it proves we are loyal customers and take care of your product, so please take care of support more in the future !!
Voffla
Inhave already reset what to do
Susheel
It's been these many days and still no solution. One learning from this is the customer service when buying Google products is almost null. No call or chat mechanism works. Infact if any people try to follow Google steps to resolve this issue then they end up resetting until they come to know that it's no more the valid approach. If all your products are meant to behave like this after support period then that's a serious issue.
Alanders
I moved home a few days ago with 5 Chromecast audio devices. I spent a few hours of valuable time trying to set up devices, struggling to figure out why they weren’t working. I wasn’t able to connect to new WiFi so reset them. Eventually found out issues were due to this Google fault. What a mess! Please inform those of us who reset our Chromecast audio devices, when can use them again.  Wish I had opted for a Sonos system now  😩
Edd42
Im so mad… of course Google did this on purpose we don’t own our devices anymore !
AGZ
Vuestro mensaje ha llegado muy tarde. Intentando solucionar el problema, lo que aparecía en vuestra página era precisamente eso y ya restablecí en mis dos dispositivos la configuración de fábrica. Ruego den una solución lo antes posible
Cnr1
I’ve reset both of mine, so will be needing guidance as to set them back up to receive the update.
Jocko6872
I already factory reset mine before I saw this message.. I have 2 chromecast audios
neither will connect to wifi
