GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,123 REPLIES 16,123
Emapecar
I did factory reset mine, as I only saw the message now. What can I do?
Change the date on you phone to before 10 March 2025. This will allow you to complete the setup process somewhat.
Then you just have to be "patient" like the rest of us and wait for Google to push out a fix...
I NOW GET THIS MESSAGE WHEN i TRY TO CAST ...
Untrusted device
Bedroom TV couldn't be verified. This could be caused by outdated device firmware.
Stew2
Cheers so not just me that’s all I wanted to know. 👍
Jabier
If I did the factory reset on my chromecast, what shpuld I do now??
paparojas
Para cuando se prevé la corrección del problema. Sale la siguiente leyenda “ se fabricó este dispositivo Chromecast para usarse en otro país y es posible que no sea compatible con tu red Wi-fi”
está trabajando bien el domingo dejo dejó de funcionar
AntB
What happened Google?! Did that idiot Trump fire the majority of you? Any company originating in brain dead US of A, who choose a moron as a leader is headed for disaster!
Francy1
Google è out!!!! An he google home non si carica da App Store! Che disastro!!!!!!!!
Annabeatriz
Olá! Já fiz a restaurante do meu aparelho, pois enfrentei alguns problemas anteriores e foi resolvido durante a restauração. Porém, como nesse caso o problema é com vocês, a restauração não resolveu. Tem alguma previsão? Pois estou a mais de uma semana sem assistir a TV....
ujjwaltrivedi
I reset it today. Looks like i am doomed. I don't think this it can be resolved now.
dede74
What would be the version number of the fix to be deployed?
Thanks.
Francy1
Perché anche l’app Google Home non si carica?
ChunLeung
我已將設備恢復原廠設置。。怎麼辦??
VanessaP
Hello, I would like to know how to fix this issue, your advice of not to factory reset the divice came almost 24 hs after the error and i did it. So, waiting for a solution and instructions. Thanks
El personal del trabajo que tenemos Chromecast ... y  audio procedimos a resetear  a modo fábrica, quería saber si alguien logró la transmisión a sus dispositivos para que nos orientara. Tristemente al igual que Usted continuamos en espera de una solución.
Anghymax25
Envíen notificación cuando esté resuelto el problema ,porque no avisaron que iba a ver un problema con el equipo así no lo reiniciabamos  50mil veces es una locura esto,solucionenlo pronto porfavor
anilmarath
My Google Chromecast is not working since 6 days, NO TV or ANY PROGRAMMES ....please HELP.. 92639950 is my Customer Support Code
I have already conducted factory reset to my Chromecast
Cicciocarloni
Ho fatto il ripristino , perche nonostante il chromecast era connesso alla rete, nell'app home non veniva visto, ne ho un altro identico che invece funziona.
Fatemi sapere come risolvere , grazie
Saperlo!!!!!!
Roberto1958
Quando sarà rilasciato il nuovo certificato ?
Grazie
Read the status update pinned at the top of this page.
RuloSgo1
Señores, por favor, respondan con una fecha estimada de resolucion para los que restablecimos de fabrica, son millones de equipos inutilzados. Muchas Gracias.
swedenho
Please let me know how to do it.
Lua
The problem happened before the explanation of the failure. I have already restarted my device and it is impossible to complete the configuration through the app. How many days will we have to wait?
Llum1
Desde donde enviaréis esa información? Llegará un email? Tenemos que adivinar? Porque, al menos a mí, no me llegó ningún aviso e hice lo que siempre decis que haga que es restablecer de fábrica.
Quelin
Olá bom dia, restaurei meu aparelho e não estou conseguindo acessar novamente para configurar, segue até etapa de localizar mas quando abre o código não segue o processo. Como faço ?? Deve trocar de aparelho este não vai mais voltar a funcionar ???
Leozinho92
Só alterar a data do celular para 8 de março de 2025 e tentar novamente que dessa vez dá certo , por em só conseguir configurar ainda não estou conseguindo abrir qualquer app YouTube , net flix e etc , falta só a atualização deles . Cuidem
RadicalBox
Hope your fix will support devices that has been reset as that has been the standard way to fix things before and I guess no one really reads this message until they see that a reset does not fix it. Really poorly managed.
