Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-14-2025 09:54 AM
Continua com problema pra conectar
03-14-2025 09:54 AM
This was posted MONDAY, doesnt seem like this is very high on your priority list, looks like I spent 65 dollars recently on a peice of plastic dog**bleep**...throwing it out as it JUST passed the return by date, and will NEVER trust google or any google home products again.
03-14-2025 09:59 AM - edited 03-14-2025 10:00 AM
It's been fixed. Read the status update pinned at the top of this page. If you've done a factory reset and are looking for that specific solution, just do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-14-2025 09:54 AM
Hasta ahora sé que no debo restablecer a la configuración de fábrica, problema ya lo hice. Entonces ahora qué tengo que hacer, porque tengo 3 dispositivos.
03-14-2025 09:58 AM
03-14-2025 09:54 AM
Hello, what to do when I have already reset my Chromecast as Chromecast is not working, i thought may reset fix the issue. So what to do now...please fix this asap
03-14-2025 09:57 AM
03-14-2025 10:04 AM
chanche data in the Mobile Phone, befor 8 March
03-14-2025 10:05 AM
cambia la data nel cellulare , metti prima dell 8 marzo, io messo 1 marzao e sta aggiornando!
03-14-2025 09:54 AM
I made reset soma days ago, now i think noto possible receive the patch by internet becouse Chromecrast not collegate to wiFee, google home not connect any more chromecrast.
03-14-2025 09:56 AM
03-14-2025 09:55 AM
Yo lo restablecí de fabrica. Antes de que ustedes informaran que no había que hacerlo. Después pude volver a concretarlo cambiando la fecha de mi dispositivo. Leí que a muchos se les ha solucionado, pero a mí no. Que tengo que hacer?
03-14-2025 10:07 AM - edited 03-14-2025 10:07 AM
Be patient. It's coming.
You might be able to provoke the update by power cycling (plugging/unplugging) your Chromecast
03-14-2025 10:10 AM
The link you posted is “page not found”. Thanks 🥹
03-14-2025 09:59 AM
03-14-2025 09:59 AM
I thought i was the only person having the problem with the chrome cast .. It keeping sayin the internet is not connecting to my phone to cast ... my child who is on the spectrum depends on the lights , pictures and time on his tv daily .
03-14-2025 10:06 AM - edited 03-14-2025 10:06 AM
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday.
03-14-2025 09:59 AM
Tenho 4 Chromecast , 2 voltaram a funcionar mas outros 2 não , pois quando deu o problema eu havia restaurado pra configuração de fábrica, O QUE EU FAÇO?
03-14-2025 10:10 AM
03-14-2025 10:01 AM
As of right now 12:29 - Friday, March 14 They updated and is now running.
03-14-2025 10:02 AM
Hi all,
I think I got to solve this issue.
I had hard reset the chromecast before reading the suggestion not to.
I set the mobile date to March 8th, and managed to reconnect the chromecast with the google home app, which successfully connected the device to the wifi (you can reset automatic date/time after adding the device to home).
At this stage I only managed to cast from laptop using VLC (not using google chrome) or from mobile using Youtube app (did not try other apps).
Against every of my hopes, the chromecast restarted and started to install the update (see photo).
Now it is correctly working, I can cast again from chrome on laptop e.g. from youtube.
Hope the fixing update will get to all of you soon!
Best
03-15-2025 02:00 AM
Do it worked in mobile
03-14-2025 10:07 AM
Any update? 🙄
03-14-2025 10:08 AM - edited 03-14-2025 10:09 AM
Read the pinned status update at the top of this page. Google started rolling out a firmware update fix yesterday, and many users have already received it and are back up and running.
03-14-2025 10:15 AM
Working now , i got three of them so will see the others
03-14-2025 10:07 AM
Per il momento il problema persiste
03-14-2025 10:08 AM
In Thailand, my friends in the community uploaded this clip, and it worked for me.
https://youtu.be/mvSpJqDk-Is?si=yYlih4HxbJbWkkAs
03-14-2025 10:10 AM
we will require directions as we did the factory reset
03-14-2025 10:12 AM
03-14-2025 10:10 AM
How long im going to wait? When u gone to fix?
03-14-2025 10:13 AM - edited 03-14-2025 10:16 AM
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday. If you've already done a factory reset, you'll need to do this to receive the update:
03-14-2025 10:13 AM
Tem previsão para normalizar?
03-14-2025 10:25 AM
Mine is working again... yippee
03-14-2025 10:14 AM
He restablecido de fabrica .Que debo esperar ahora ? Como sabré cuando hay solución para mi ?
Y que tengo que hacer ?
Gracias
03-14-2025 10:21 AM
03-14-2025 10:15 AM
Ho già ripristinato le istituzioni di fabbrica adesso cosa bisogna aspettare? Tra quanto tornerà a funzionare?
03-14-2025 10:20 AM
03-14-2025 10:17 AM
If you have done a factory reset on your chromecast, just set your date and time on your phone to 8th March 2025 and complete setup and then put your phone back to normal time 🙂
03-14-2025 10:19 AM
Oops I read this after I posted. Thank you.
03-14-2025 10:16 AM
Is there a way if this happens again to be notified via email of this issue so we know not to factory reset. Unfortunately I made this mistake.
