GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Jotape
No meu caso, uso um Chromecast desses numa TV Sony Bravia meio antiga. Funcionou bem até recentemente, mas, do nada parou. Quando entro no Google Home, ele reconhece o equipamento, mas não o autentica.
Read the pinned status update at the top of this page. Google started rolling at a firmware update fix yesterday. Your Chromecast should receive it soon.
Sugarsmith3
I performed the update to Chromecast however it still does not cast from my iPhone.
Anonymous
Not applicable
Try unplugging it and then plug it back in which will force a reboot and it might work after that just give it a little bit of time.
Don't use that eaten apple 🍎 😉
Like the story in paradise,, don't eat the apple..
Yoli
Hola cuánto se va a tardar en recuperar el Chromecast que intenté reparar con devolver a su estado de fábrica gracias
Esperanza2102
I did performed a factory reset. What should I do?
LucianaCabral
Chromecast came back in Brazil!😀🎉
lLink
I tried to put the date on my phone back, march 6th. After that I tried to re-connect with my chromecast in the Google home app, what worked. At last I had to put the date back to today so I could cast. Now I can happily cast again! 😀
Maurizio1960
Ho ripristinato le impostazioni di fabbrica prima di aver letto il vostro messaggio. Il dispositivo tornerà a funzionare?
oropher
Do not do anything, WAIT!!
Anonymous
Not applicable
Actually I just set up six devices and you can actually try to force an update now if you just unplug it and plug it back in and give it some time.
That just worked for six of my chrome cast audio, I'm also now having to activate my three brand new spares. It's working for those as well.
Carlin
Buenas tardes aún no he podido solucionar mi equipo Chromecast me sucedió que lo reinicie de fábrica
Besilly
I only factory reset my device because your troubleshooting website said so ………… now what !?
Susheel
Finally the issue is resolved and I'm able to cast videos. It did two updates and two restarts after which it started showing the option to cast in phone.
Thanks to Google to finally solve it but I'm sure it's been a eye opener for both the producer and consumer.
AndriiBakush
I have already reset it to factory settings, but it still won't work. How do I fix this?
HelenadeTroya
Yo restablecí,cambie la fecha y nada funcionó y aquí sigo esperando arduamente la solución.
ilpacifico
buonasera,
ho eseguito hard reset al mio dispositivo chromecast 2nd gen. dopo il crash di qualche giorno fa ed ora non riesco a scaricare il fix tramite aggiornamento , come posso risolvere? grazie
Jens_001
Yippie. I managed to fix my crashed Chromecast. I had, of course, factory reset it, which you should definitely not do.
 But I managed to reconnect it again by changing the date on the mobile until February 10. Then I could fool it that the error had not occurred yet, so I could set it up with the Home app. Immediately afterwards, the Chromecast downloaded Google's new update that fixes the bug. Then I put the date correct again. Success!
Fanny4
Restableci de fabrica mi Chromecast pensando que era un problema con mi red o algo, pero apenas voy leyendo está información. Que puedo hacer al respecto? Podrían ayudarme por favor?
Csouza79
Fiz o reset no meu Chromecast 2 geração, pois não havia recebido nenhuma mensagem sobre esse erro, achei que resolvesse resetando, estou frustrado por haver uma solução nesse momento para o meu caso, espero uma solução o mais breve possível.
JuneEtta
Anyone get chromecast to work yet?
BT4
Yes. I did what another member said.
Manually reset your casting devices date to the 7th March or before, ie your phone or tablet. Then go through the setup process in home again. I had tried factory reset
Gilo1
Purtroppo ho ripristinato il dispositivo e non riesco a configurarlo .
Suggar95
Buenos días!. Tengo 3 Chromecast y no me funcionan desde hace días. Para cuando se solucionará la incidencia? Un saludo.
Anonymous
Not applicable
He cambiado la fecha a uno de marzo, he borrado la aplicación home y volviendo a instalar me ha permitido configurar chromecast. Al volver a poner la fecha actual parece que sigue funcionando
La fecha del tlf???
Anonymous
Not applicable
Si, la fecha del telefono
Hice lo mismo y así lo solucioné!!!!!
nmerencio
Y cuando se solucionará?????
