GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
Nothing will work untill they update.not your fault
Ripristinato più volte non va
KatulyAlves
Eu reiniceiei ele restaurei padrão de fábrica, o que eu faço agora??? Isso antes de receber esse e-mail 😢
Oi meu amor, olha só... tu volta a data do teu celular pro dia 7 de março. Configura ele no Google home, aí então tu volta a data ao normal e aguarda. Em umas hs ele baixa sozinho a atualização. O meu já está funcionando. Calma que dá certo.
Muito obrigada, deu certo, agirá é só esperar atualizar 🙏🏻
SandyC
Thankyou. I'm from Ireland I was just on the phone to the team.thankyou fir letting us know
anab71
Estamos a sábado y sigo sin funcionamiento. Ya está bien. Cuando piensan dar una solución?
Lucreziabelvede
Vorrei sapere se state cercando di ripristinare il problema o aspettate che si compri un altra chromecast?
I updated Google Chrome and changed the date on my phone (08/03/2025). Google Chrome has updated and is working fine now!!!
SandyC
It's nothing to do with the date on your phone. It's the software of the chrinecast
Joesr
Does this include the Nest speaker?  Says it cannot to my account
SandyC
Yes it does
Guilherme_sa
In my case, I already performed a factory reset. How can I fixed that?
Read instructions they gave you
EvenB
Hi, when can we expect a solution on this. Waiting…
Obrigada ja funciona !!
proxion
Hola a todos, ya pude solucionar el tema de Chromecast para todas las versiones.
KevinJSmiley
I have 3 Chromecast Audios and 1 Chromecast 2nd Gen (which I did a factory reset on).  I'm happy to report that they are all working again.  For the Chromecast I set the date to March 7th on my android phone to configure it with the Home app.  Thanks for fixing this.
anab71
Estamos a sábado y sigue sin funcionar . El mío está configurado y lo reconoce desde móvil y tablet pero no hay manera de que conecten.
Anonymous
Not applicable
Bonjour je n'arrive toujours pas a reconnecter mon chromecast
Anonymous
Not applicable
I did a factory reset as soon as the problem occurred and today March 15, 2025, the problem is still not solved.
Eu fiz a reposicao, segui este conselho e funcionou logo ! Obrigada
Pbi7
Yo estoy igual
jordydr
tool late. In the Google Troubleshooting guide there is a step that suggest to factory reset the device. Now i'm offline. How can i solve the issue?
Thanks you so much. It works!
Superk1976
Is this also affecting google Minis? All of my minis & audios keep disconnecting from the WiFi. They disconnect at least once a day. I have 2 minis, 3 audios. It's very frustrating!
Tony6567
Ho ripristinato il dispositivo e non và,lo lascio acceso o spento?
p21
Acabei reiniciando ele.
If by "restarted" you mean you did a factory reset, then you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
johnnyzero2
**There is a known fix to recover from a factory reset, and it's ridiculous that Google hasn't pinned that information to the top of this page!
Literally 90% of the people now posting here are saying "I've done a factory reset, now what can I do?" or "Any update on a fix for those who have done a factory reset??".
In the meantime, I've been posting the solution everywhere I can to help those affected:
RafaelCrosa
Hola , mi paciencia se agota y no soy el único
Cuánto va a demorar ?   Tengo un dispositivo que no sirve para nada y no es culpa mía
Lo reinicie y resulta que fue peor , porque no lo previeron
Me dijeron recién que cambie la fecha en mi celular de antes de la actualización, puse 1ro de marzo. Ahí me leyó el Chromecast qué no me funcionaba desde el Google home. Luego de que termino de hacer la actualización, volví la fecha a hoy y ya me deja usarlo. Espero que también puedas. Abrazo
Personalmente non ho fatto cambiamenti al mio cellulare, né do orario, né di giorno, né di nulla.All'improvviso mi è scomparsa l'icona del chromecast dal televisore, dal cellulare non potevo più trasmettere a video....... Il macello ahahahah
