Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-15-2025 04:28 PM
You need to change your phones date back to march 8th and you can set the Chromecast back up. Once it is set back up, it will download the new firmware. Don't forget to change the date back on your phone when done!
03-15-2025 04:47 PM
Cuando lo vais a solucionar estoy cansada ya de esto! Como puede ser que esto falle de esta manera algo tan simple y no deis la solución ya!!!
03-15-2025 04:51 PM
>> If you are one of the many users who have performed a factory reset, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-15-2025 08:37 AM
03-15-2025 08:47 AM
Anche io sono diventata matta…. Spero agiustino presto e mandano email
03-15-2025 04:50 PM
03-15-2025 04:48 PM
Hi I tried to re add device to Google home still having the same problem it gets through most of set up comes up with code then does nothing after that
I'm getting a message at bottom of screen saying Chromecast2666
03-15-2025 04:52 PM
***If you are one of the many users who have performed a factory reset, you'll need to do this:
03-15-2025 04:51 PM
When os Chromecast expected to return? Mine still doesn't work
03-15-2025 04:55 PM
If you performed a factory reset during your initial troubleshooting, then you will need to do this:
03-15-2025 04:51 PM
Hola aun no puedo configurar mi chromecast
03-15-2025 04:53 PM
03-15-2025 04:52 PM
Still no fix? 3/15/25.
03-15-2025 04:53 PM
03-15-2025 04:53 PM
Buenas tardes yo reinicie el chomecast pero aun me sale sin poder conectar estoy esperando sus instrucciones para ver que paso procede por favor solucionen pronto
03-15-2025 04:56 PM
If you performed a factory reset during your initial troubleshooting, you'll need to do this:
03-15-2025 04:55 PM
Any update or ETA to this issue can be resolved?
Thank you
03-15-2025 04:57 PM
03-15-2025 04:54 PM
Já está demorando muito esse problema. Tentei reiniciar achando que esse era problema e não era. Qual o prazo pra resolver isso, pelo amor de Deus.
03-15-2025 04:58 PM
*If you performed a factory reset during your initial troubleshooting, you'll need to do this:
03-15-2025 03:00 AM
Chrome cast not working
03-15-2025 05:00 PM
03-15-2025 09:30 PM
It worked!! Date changed (could only do that on iPad not iPhone)!! WiFi connected!! Waiting for update and streaming blast off!!
03-16-2025 10:01 AM
Maria , não sei se vc é brasileira, mas estou com dois Chromecast que não estão funcionando. Vc sabe se estão fazendo alguma atualização?
03-15-2025 02:59 PM
Preciso das instruções de como configurar meu chromecast de 2 geração depois desse bug. Ele está resetado para as configurações de fábrica
03-15-2025 05:01 PM
03-15-2025 05:50 AM
Nach Werksreset am Handy das Datum vom 9.03. einstellen, dann kann man Chromecast erneut installieren. Bei mir hat es so funktioniert. Danach ist das Datum am Handy wieder auf dem neuesten Stand, sonst geht es nicht.
03-15-2025 05:02 PM
Tenho dois dispositivos o que eu não restaurei a padrão de fábrica voltou a funcionar perfeitamente mas o outro eu restaurei e não estou conseguindo configurar novamente.
03-15-2025 05:05 PM
*** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
03-15-2025 05:06 PM
Não consigo reconfigurar meu Chromecast, como faço? Ele não está sendo reconhecido
03-15-2025 05:09 PM
03-15-2025 05:10 PM
Restaurei as configurações de fabrica no meu, não consigo instalar de novo.
03-15-2025 05:13 PM
03-15-2025 05:12 PM
Is this a general advice for your products now? To not attempt to fix problems by factory resetting?
03-15-2025 05:14 PM
03-15-2025 05:13 PM
03-15-2025 05:13 PM
So frustrating when the go to method was factory reset 😒
03-15-2025 05:16 PM
03-15-2025 05:12 PM
This is ridiculous. Fix our Chromecasts!
03-15-2025 05:15 PM
