Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-15-2025 06:18 PM
>>>> If you performed a factory reset during initial troubleshooting, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-15-2025 06:16 PM
por favor vean este video y recomienden. https://youtube.com/@tipsgabo?si=AxG3LguUJ45B_2P0
03-15-2025 06:19 PM
That you for continuing to support the hardware. I did factory reset and am looking forward to your instructions.
03-15-2025 06:20 PM
*** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
03-15-2025 06:21 PM
Hasta cuando carajos van a resolver el maldito problema de la autenticacion !!!!
Son unos bastardas!!!
03-15-2025 06:23 PM
03-15-2025 06:23 PM
Reset already, now it says "TV may be setup, but could not communicate with it from your IPAD."
03-15-2025 06:24 PM
> If you performed a factory reset during your initial troubleshooting, you'll need to do this...
03-15-2025 06:28 PM
Pedindo pra atualizar
03-15-2025 06:30 PM
03-15-2025 06:28 PM
Buenas noches, mi Chrome cast presenta este error , y lo reinicie de fabrica:
No se pudo autenticar tu Chromecast. Visita support.google.com/chromecast para obtener ayuda sobre cómo solucionar este problema.
Por favor me ayudan , gracias
03-15-2025 06:35 PM
03-15-2025 06:31 PM
Pensé que ustedes eran los mejores, que equivocado estaba.
03-15-2025 06:36 PM
03-15-2025 06:31 PM
Yo lo reinicie, que debo hacer?
03-15-2025 06:34 PM
03-16-2025 12:03 AM
It worked
03-15-2025 06:34 PM
I have reboot from fabric my devine, Please let me know how I can fix these problem.
03-15-2025 06:51 PM
03-15-2025 06:41 PM
I Buy a Firestick ❤️ thanks for this. 😒
03-15-2025 06:47 PM
Cuando se va a reestablecer el servicio
03-15-2025 06:52 PM
**** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
03-15-2025 07:05 PM
Do I need return the date in automatic set up even the loading is not yet done?
03-15-2025 06:55 PM
Es una vergüenza lo que está pasando y un desprestigio para google
03-15-2025 06:54 PM
I have 3 chromecast 2nd generation
2 of them back to work tonight
the one that I reset the factory settings is not working yet
I hop you fix the problem soon
03-15-2025 06:58 PM - edited 03-15-2025 06:58 PM
For the one that you factory reset, you'll need to do this:
03-15-2025 06:53 PM
Até quando vou ter que esperar pra ser concertado?
03-15-2025 06:57 PM
Preciso usar para desenhos pro meu filhote
03-15-2025 06:59 PM
--- If you performed a factory reset during your initial troubleshooting, you'll need to do this:
03-15-2025 07:00 PM
----- If you performed a factory reset during your initial troubleshooting, you'll need to do this:
03-15-2025 06:56 PM
I can't started de chromcast
03-15-2025 07:00 PM
03-15-2025 06:56 PM
We already reset them
03-15-2025 06:57 PM
03-15-2025 06:58 PM
Por favor envíen la actualización que no podemos ver tv sin el crhomecast y para eso hemos invertido en la compra para poder vincular gracias
03-15-2025 07:01 PM - edited 03-15-2025 07:01 PM
03-15-2025 07:03 PM
Olá boa noite. Estou sem acesso ao Chromecast a uma semana.
03-15-2025 07:08 PM
---> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
03-15-2025 07:12 PM
If, like me, you did a factory reset before knowing not to... simply change the date on your phone to March 1st before the sh!t hit the fan, chromecast will do the update and then all will be right with the casting world again 😊 you're welcome
03-15-2025 07:15 PM - edited 03-15-2025 07:41 PM
Yes, that's part of the trick. But you left out the part about using the Google Home app to reconnect the Chromecast to your Wi-Fi network, which is kind of important. 🙂
Complete instructions here:
