GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,152 REPLIES 16,152
MiloSofi
Same issue here
Micmic
Same here
Gordo97233
Same in Caribbean...brick ???
vsh
Same here.  My Chromecast device is hard-wired (enet-usb adapter); I can ping the device from my laptop and from my phone, but Google Home can't see it, and (obviously) nothing can cast to it.  It was working fine yesterday.
Same just happen
vsh
FYI:  According to this post, it's because old (Gen-2) chromecast devices have a built-in certification key that expired on March 9, 2025.  Presumably, after 10 years, nobody at Google remembered that this was going to happen.  The post says Google should be able to update the Google-Home app so that the chromecast devices will work again, but it will take some time.  😞
Djb200
Thanks for the info x
Micmic
My chromecast just stop working. Why?
kate16
seems to be world wide. Google created problem
Hela världen?
TzarLo
Global issue I think.
Rocket67
3 chromecast devices suddenly stopped working, guessing a Google glitch ?
xerox97
Samething happened to me. But only one of my chromecast device is not being recognized. However it is an older version.
Bdmack
Same here
xerox97
it was literally working fine yesterday.
xerox97
maybe its there way of telling me to buy a new one haha
SharnNZ
When will Google tell us what the problem is? It’s been over 6 hours now!
edward8
Yes, Chromecast audio stopped working today. I did factory reset but haven't been able to get it working again using Google Home app.
My Chromecast failed to connect today was still connecting to the internet but could not cast anything to it so I went through the factory reset and now the home app sees it but cannot connect to it what gives Google
Exact same issue as me...
Djb200
Same at 3:20 am for last hour. Tried resetting Chromecast for both Android and iPad. Wasted so much time. Finally found this community so.it appears to be a failure across the board. (Black disc model).
Greg19
Même problème pour moi depuis hier sur chromecast audio et vidéo 2nd gen. Rien à faire j'ai tout essayé et la demande au support reste en attente
MowokS
I'm glad to see I'm not alone with this problem.
3 devices are unvailable to cast: 2 audio and 1 video dongles.
I tried to reset the video one but the process to reconfig fails.
I have no clue to solve that.
Jaybalanced
Shed TV may be set up, but we could not communicate with it from your iPad. Make sure that you have enabled local network access in your iPad’s privacy settings. Then try again. What is this for? I’ve reset everything
Teltel
Chromecast not working anymore just working yesterday anf now cannot cast anymore
Jo98
Same
Malenacagnani
No funciona mi cromecast me pide Dispositivo no confiable No se pudo verificar Dormitorio. Esto puede deberse a que el firmware del dispositivo está desactualizado. Y no pasa nada
Me está pasando exactamente igual, parece ser que es un problema masivo
Estamos igual dejo de funcionar de golpe
Teltel
Any guide how to work the chromecast today is not working anymore cannot even find the device even we go to home apps..
And cannot even update the device coz it is no longer searchable
Ange177
bump, same issue
You are not alone, same here in the Philippines
Rbees
My Chromecast 2nd (or maybe 3rd generation) is not working since last few hours. I am not able to cast content from my smartphone to TV. I tried all the possible solutions given in Google support (troubleshooting) to connect it but nothing happened . 'Google Home App' is not reflecting my device title... I came to know from Reddit and other social sites that many users are facing the same problem since last many hours. Why is this happening? When will Google fix this?
BaronSengir
Chromecast 2gen stopped working due to a certificate error .. I tried my spare one but got the same error ... Reserved bout of them and now they can't be installed in Google home .. it connects to them but times out during installation after connecting to them...  And why do o fins out there is a problem on Reddit and trending searches on Google ... Instead from Google ...
Elinalis
Mis chromecast no funcionan desde ayer. Desinstale la aplicacion de google home para reinstalarla pensanfo que asi lo solucionaba y ahira ni siquiera puedo instalarla nuevamente.
EkuP
Por lo que leo es un problema a nivel mundial. Ojalá lo solucionen pronto!
bumbJiggyK
Have 2nd gen w/  275994 firmware, 24 Feb 25. In device info (that I can no longer access but screen capped) my Home is dimmed out/no permission. Says I have preview program (but shouldn't-do believe I opt out of everything) I didn't get the chance to click on everything else, because I was busy doing all of the resets/factory reset/reset router/hard phone reboot/uninstall-reinstall Home-so that, I am now stuck at the point of it telling me I cannot connect (strangely one time I was able to see notation that I needed to be connected to the same WiFi as my mobile device-however it clearly shows that both are connected to the same-however the CC will not complete the reconnect. It worked fine throughout the day. It is, however, as though I do not have 'control' or permission on my CC device however. BUT am the only one in the 'home' and the only Admin. I'd replied to a Diamond contact, can't remember where in this place, so am doing a stand alone post. I DID try to write down everything, and did get that screen cap-because I think that holds an answer. AI glitch or coding bug? It can't be from the update after this long of time, imo. I see this is not a locality issue, so am trying to provide as much info as I can, to maybe help this along.
DarkJedi
Any idea when Google will fix the problem with the certificate for gen2 Chromecast users ? It's been down for 12 hours already.
I get an error code S S C R-
S 4 0 1 0-2 2 0 3 -
2280-G
