GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,134 REPLIES 16,134
Ppa
Bonjour
Avez vous une date
Bonne journée
Anonymous
Not applicable
The process of setting the time back to before March 9th works for me, and my chromecast is working again
Simone281
Vai demorar muito pra essa correção?  fiz restauração e não conecta.
Tolgadcolor1907
bir haftadır çözülemeyen bu sorunu ne zaman çözmeyi planlıyorsunuz
Xctvamsd1ROLLY_
Yes, i have a probleme to connect my Phone to my Tv by mirroring.
Lippe
Falta muito para resolver o problema ???
Benny62
Ho fatto reset come avevate indicato.
Ora dite che non bisogna farlo.
Non capisco quindi se il dispositivo è  connesso seppur non configurabile *per colpa di GOOGLE*.
Se avete messo un fine vita al dispositivo dovete rimborsare o fornire un altro dispositivo gratuitamente , altrimenti siete censurabile e perseguibili
Gbond2
Awaiting for the resolution for the factory restored devices.
Zimo81
Its been a week now😪 whats status for the rest of us!!
Anonymous
Not applicable
Hi. Just a heads up. All my Chromecast audio are back up and online as of yesterday. I know you were accidentally at fault but Thankyou for the effort and time you have taken to fix the issue. I appreciate it. Thankyou again
Mine were back up for all of a day and a half and now are doing the exact same thing again
Equalizer_Goth
There is a workarround to solve not casting from a computer to a tv.
Do it only from a chrimium webbrowser on the computer who you wanna cast from.
computer does not need to be in the google home app, but have a corded networkskabel to your wifi router.
your google home only needs the chromecast, on thevsame wifi.
omportat
use apps on mobile.
do not use netflix app, youtube app on tv.
works.
haidi
First thing what is always told to do from anywhere is the factory reset and I have done it many days ago now. If you're response would be more on time it would be different Matter😑 very upsett from this. This basically means I haven't got a tv for a week now and don't even know when I get it back.
Maria65
If you scroll down, you’ll see how you can reconnect the chromecast to your WiFi. When I did it last night, I couldn’t stream right away. Woke up this morning and gave it a try and now I can stream it all!!!! Look for it and give it a try! You need to reset the time on your phone or tablet to before March 7th and then connect to your WiFi.
marcia4
Eu ainda não consigo conectar o Chrome cast na TV e nem no celular. Infelizmente eu resetei domingo passado achando que seria problema com a internet.
Kwanza67
Google
Oldandgrumpy
This has been down for a week now. You are supposed to be one of the largest tech companies around and you can't fix a glitch like this? You have got me and millions of others looking for an alternative that has nothing to do with Google. I shall be replacing EVERYTHING associated with you because you made no warning, which meant people were tearing their hair out trying to fix what they thought was just their problem when all the time it was a global issue and you were sat on your fat corporate arses doing nothing. YOU HAVE LOST THE RESPECT OF MILLIONS AT A STROKE, WHAT A WAY TO RUN A BUSSINESS ............INTO THE GROUND.
ALINEst
Não é paciência, é falta de opção.
GersonAlves009
Tem previsão para normalizar ?
Jeanmarcelo
Restaurei o meu e nao consigo mais conecta
Stroh300
I factory reset my device. What do i need to do?
Anonymous
Not applicable
Set the date on your phone to a date before 9. mars. And then start all over again with your CC. Remember to set the correct time afterwards.
GlennFeit
All Fixed, even the factory reset devices!
I have three Chromecast Audio device. I factory reset two before I saw the warning here.
On Friday, the fix came through for the one Chromecast Audio device that was not factory reset.
Today, I was able to fix the two remaining Chromecast Audio devices!
By manually adjusting the date on my phone to the day before the Chromecast's security certificate expiration date (March 9, 2025, the root cause of the problem) I was able to set them up, allowing the firmware fix from Google to install.
All of the (3) Chromecast Audio devices are now operating beautifully!
Gesu
Bonjour
mon Google chromecast ne fonctionne toujours pas. Il est configuré et connecte au wifi mais mon téléphone ne peut pas communiquer avec lui. L’installation ne se finalise pas.
Le problème a commence dimanche dernier et comme je n’avais pas eu l’info d’un problème de mise à jour de votre appareil je l’ai réinitialisé. Que dois-je faire pour que cela fonctionne maintenant ? 1 semaine en panne !!!
Van4
Oii eu restaurei e agora ?
Marlimarl
So when will it be fixed???
Try to update your device date to 1st March 2025 and then connect chromecast to get updated.it will be working after taking time to update
Fahadii024
mb21uk
It is fix, and many in this thread have explained what to do if you did a factory reset.
Bmc76
Result! Had factory reset my device and disconnected Chromecast device from Home app before realising it was a general global fault earlier in the week, but couldn't reinstall as Home app on phone couldn't find device all week. Disconnected the cast at plug and TV, updated Home app on phone via Google Play store, plugged Chromecast back into both plug and TV, and managed to connect via laptop first last night after manually changing the date in laptop settings to march 8.  After that it connected fine to Netflix and YouTube. And now connects to my phone as well fine. Hope that works for others too.
Lueciabarros693
Não está pegando
IEC
It’s working again (in the Netherlands)! After a datefix on my phone yesterday to undo the factory reset, the chromecast is casting again today. So apparently, they’ve updatet something.
Anonymous
Not applicable
The same here in Denmark 🇩🇰
PaulaKarol
I managed to set mine up like this too, setting the date to March 7, 2025.
Eu consegui configurar o meu assim também, colocando a data para o dia 7 de março de 2025.
MarieSchmidt09
We have performed a factory reset. Please advise how to proceed from here. Thank in advance
Try to update your device date to 1st March 2025 and then connect chromecast and follow the update of Chromecast.
Fahadii024
how do you change the device date?
By changing the date on your phone and then you do a new setup to your chromecast from there
Go to your phone or iphone and then go to clock setting and set off update time from gps and set it to 1st march.then connect chromecast and update it.
Fahadii024
Anonymous
Not applicable
Se cambia la fecha del teléfono y despues lo configuras
Graziele
Bom dia , estou a duas sem conseguir usar meu aparelho devidamente, não tenho outra forma de usar a tv ,gostaria de uma solução imediata
