GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,124 REPLIES 16,124
Brilha
Muito obrigada pelas dicas! Trocar a data para 1 de março pra reconfigurar deu super certo!!
FahadKhan911
Confermo a tutti che basta rimettere la data e l'ora del telefono al 1 Marzo 2025. Anche se avete fatto il reset. Riconfigurate con l'app Google home e successivamente rimettete l'ora del telefono a quella della data odierna.
Fahadii024
Shivamsoni
Please resolve the issue asap as I have already reset the Chromecast device
Just change the device date(phone or tablet or iphone )to 1st or 3rd March 2025 then connect chromecast.it will take some seconds to download and update the chromecast.after that connect to the wifi and enjoy streaming.i already did that.its working.
Fahadii024
-->>  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
**Google REALLY should pin this information to the top of this support page!!!**
Jar3
  • Si Jonny, mañana hago un curso de sistema y lo resuelvo, , nosotros no somos expertos en sistema, necesitamos el apoyo de el personal especializado,
SergiTallon
Buenas tardes, el pasado viernes escribí un mail a soporte de Google indicando esta solucion que te voy mostrar y me respondieron como sigan tuviera el problema... sin más... ahí va como yo lo arregle:
De: Sergi Tallon
Date: vie, 14 mar 2025, 23:06
Subject: Solucion para que se actualize el certificado de Google ChromeCast en dispositivos que se han restablecido de fabrica en el fallo del 9 de marzo del 2025
To: chromecast-support-eu
Buenas noches,
La Solucion para que se actualize el certificado de Google ChromeCast en dispositivos que se han restablecido de fabrica después  del fallo del 9 de marzo del
2025, es tan fácil como cambiar el día al 1 de Marzo del 2025 en el telefono movil que se quiere sincronizar/configurar/agregar Chromecast a Google Home nuevamente desdey volver a sincronizar de forma estándar desde Google Home.
Una vez está establecida la conexión con el WiFi en Chromecast, automáticamente se actualiza nuevamente el certificado y ya vuelve a funcionar.
Saludos,
Sergi Tallon
SunyJim
RESET SOLUTION
I had reset my Chromecast audio as part of troubleshooting. Then of course was in trouble as nothing worked and the unit would not authenticate.  So i changed my phone date to March 1st/2025,  google home, add device, connected to the chromecast gave it wifi info.  At this point i had to change the date back because my phone Samsung S22+ wouldn't give me internet on the phone with the wrong date.  Then the chromecast seemed to sit and blink white, then reboot orange, then back on, then it finally showed up in the devices list.  (be patient). I've confirmed it now has the new updated firmware.
happy to report now working.
Sundasafroz
Some body stolen my fon I want to know the exact location
Paolo1966
Grazie dell'informazione
tantraclaymore
No tengo conexión
Gabriel76
6 meses de uso y dejo de funcionar, malo el dispositivo.
Rangelewe
Previsão do problema ser solucionado
-------->> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Helekin
I restored to factory configuration. I need to know how I do it to go back normal.
Xiukieu
Xin chào . Bạn ở đau monhf ở vietnam
---->> If you performed a factory reset during your initial troubleshooting, you'll need to do this.....
Linda90
I have this issue.
I have also factory reset my device but when is it all good to go again?
Xiukieu
Chao e .lunda ở đau ak nak
smy3187
Please guide me I have already reset my Chromecast gen2
Manhatthien98
http://www.sprint.com/en/support/contact-us.html
Truy cập bị từ chối
Bạn không có quyền truy cập "http://www.sprint.com/en/support/contact-us.html" trên máy chủ này.
Tham chiếu #18.1e6633b8.1742144171.1159e5b2
https://errors.edgesuite.net/18.1e6633b8.1742144171.1159e5b2
Chưa Ký
O meu aparelho,apareseu, faça download do app home e abra-o  no seu smartphone para começar a configurar
Já fiz,mas não dá???
Maimon
I already reseted the device. Still trying to make it work, 1 week after that.
Thanks, but I dont know how. Do tou mind explaining please?
RemcoW
Never mind I know, thanks.
vheeno
i set my date march 1 then it worked. even updates....
thanks 🙏
RemcoW
Yes this works! Thanks!
and shame on you Google for how this was (not) communicated.
Ouvi falar que pode criar problemas nos app de banco,  caso tenha em seu dispositivo.
  • The date switch is only a temporary measure to re-setup your chromecast. Once you're done, you can change it back to Auto.
Robbinkakebeen
Verbindingen
Conz195
I changed my date on phone setting and it genuinely connected  and is now working .  No issues  just fully confused how that has managed to fix it lol
pedrooliveira
Boa tarde,  consegui resolver o meu voltei a data do celular para 03/03/2025, segui para configuração, quando ele for pedir pra conectar no chromecast pelo Wi-Fi vai precisar entrar nas configurações do Wi-Fi e esquecer todas as redes salvas que seu celular possa conectar, ele vai seguir e conectar no crhomecast daí ele vai pedir pra vc colocar a senha do Wi-Fi no celular daí ele vai começar a atualização do chromecast e tudo volta ao normal, espero ter ajudado.
Sujitra
I had already factory reset my device. How can I do it?
MumTheMightyGod
I hope this helps ..I followed advice from previous community member
I had already factory reset my chrome before being warned not to .
So this is what I did ...
I changed date on my android phone to 7th March .
I searched for cast device through home again and it connected to it easily again.
Had a little weird back and forth where it said it hadn't connected yet it had on the TV .
The Chromecast started an update which also stopped and started but I let it do it's thing and it completed and restarted itself.
I did a hard reset/reboot on my phone (you know,where you hold the on/off button for ages and then reset)
I set the time and date back to automatic in settings on my phone.
This seems to have fixed the cast problems and am very happy to have my chrome cast back again ,I didn't know how much I would miss it .
Hope this helps
