GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,162 REPLIES 16,162
mrsilvis
Chromcast won't connect, worked fine this morning. Tried a factory reset and now I'm getting a "cannot authenticate" error message. Fix it google. And if you killed the 2nd gen I'm taking my business elsewhere and not buying your next product
Anand2
My Chromecast also having authentication problems.
Genec67
Same here
Having same issues
Wow me too . What’s the dwal
Danishmadara
The device was working for years and all of a sudden it stopped working.
it says
TV may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your Phone’s privacy settings. Then try again.
I resettled/factory Reset multiple times, manually connected to Chromecast ID but then the Google Home doesn’t finds it.
reset modem, tried everything that I know.
can someone please help
It seems like the issue is from Google. I changed the date to yesterday and I can add the chrome cast back. It’s still not working but this confirms it.
This is just happening to me. It’s so frustrating! I’ve tried everything, but there seems to be no fix. Very annoyed!
Yup, not sure what’s taking Google so long to fix
I have the same problem since yesterday (March 9th 2025)
ohh I though only me happen this, let me know if have already solve for this matter,
I’m experiencing the exact same thing since March 8th, 2025. I was on the phone with Roger’s for an hour thinking it was my wifi, but we exhausted all options and the issue seems to be with Google. When you request a call from customer service they don’t actually call you?
Same issue still ongoing. Have also factory reset, checked all settings and called broadband provider.
Davenuerge
I factory reset three of my four Chromecast audios before I found this post.
WTFonchromecast
Do not factory reset your device -  Totally BS non-sense. You should update your help web pages, it said factory reset your device.  😡😠😠
WTFonchromecast
Do not factory reset your device -  this is totally Non-sense. your help website said, factory reset it and I did it !!! 😡😡😡
LauranceHsu
所有排除錯誤文檔說明,最後一個都是重置裝置,現在才說不要恢復原廠設定是否太慢?
早就不知道重置幾次了
BillyinTO
Already tried factory reset... Anyway, please fix it ASAP. And please let us know ASAP.
Firemonkey
How will you notify us?
LeoStuart
Hi Team Google Please Fix the Certification thing and get the Google Chromecast started it has stopped working since over 12 hrs now have reseted it multiple times but it's not been able to connect thru phone... It just says can't recognise and connect to support... But even there there is no help... Offered
The same thing is happening with ours.  Tried factory reset multiple times and everything else google help
sugested
Same thing happened to me, and I did exactly the same as you did. Have you received any information about the problem? It was ok yesterday night...
Ditto. The most useful thing I’ve read so far was on an outside source which suggested doing a factory reset as we’ve all instinctively tried is a bad idea because it will be harder for the device to get a firmware update. I hope this isn’t the case, but I’m anxious to hear *something* from Google. Even to the extent of a vague description of the true nature of the problem and what’s being done about it.
JJFoo
Same for me and thousands of others reporting the same issue via Reddit.
According to several users there is an expiration date in the code that needs to be fixed... hopefully it's being fixed. People are reporting the very same problem from all over the world. Here is what a user wrote from looking at the code...
"...There's our problem:  *(Not After: March 9th sixteen, forty four, thirty nine of this year GMT!) Google issued an intermediate CA, presumably the one for all 2nd-gen devices, with a validity period of only 10 years, and it just expired. As a result, none of Google's official clients succeed in validating the device as genuine and they refuse to talk to it, including during initial setup.
Google can fix this. Not by rotating every device's auth certificate to a new CA, which would take significant development work and is probably infeasible, but by hardcoding the fingerprint of the problematic CA into their clients and either pinning it as a root of trust (in which case the expiration date is ignored automatically) or ignoring its expiration date when performing device auth. I expect them to do exactly that,"
I'm hoping someone at Google reads this and takes the suggestion and/or fixes this on the quicker side. I think a whole lot of Google users are assuming this was done on purpose and ready to throw in the towel on any Google products. Folks are tired of feeling scammed by big corporations.
Fingers crossed it was an oversight and they'll fix it asap.
*note:  system wouldn't let me send a reply with the (actual coding due to the date/time) and numbers I guess
Lom
Thanks for your answer. Wished I read it yesterday...
JJFoo
LOL, me too! 😂
Thanks for post. It helped better than any google responses. I had problems with second generation chromecast and audio. Today my audio reconnected but not my chromecast tv. But I did reboot tv and not audio.
Same problem here in the UK . Had also affected my Chromecast audio
It's been over 24 hours for mine,I'm fuming haha
LeoStuart
@GoogleNestTeam This is not done... All of a sudden all my streaming devices stopped working... I fixed to Resety Mi Home Speaker and it started working but the Main issue is with My Google Chromecast 2nd Gen Where after multiple attempts I am unable to connect... And it says unable to recognise... Or your wifi couldn't authenticate... Kindly check and fix this issue i want to run my but and I can't sit without running my adds on my TV... Please fix this issue asap
Estoy en la misma... Me sale que no se puede autenticar el Chromecast
Sully4
Ayuda por favor todos tenemos el mismo problema, que está pasando que no se puede autenticar el chromecast
Por favor hagan algo o acaso quedaron obsoletos nuestros chromecast?
Nicco61
I have had a chromecast that was been working fine, then it suddenly stopped connecting. I did a WiFi reboot and all the work arounds including resetting the Chromecast to factory settings using the side button and unplugging. When the device is on I can see it as a new Chromecast in my app, and after my phone discovers the device I receive a a connection Failed message when I’m supposed to confirm a code on the tv screen. Everything is connected to the same WiFi, as I can verify looking at my WiFi app. Please help!
LexiC
Mine did the same, I did a factory reset and now it's saying it can't authenticate my device.... I guess several people having this issue
Cherb
Exactly the same as me.....
Peg2
Bonjour pareil pour moi tout fonctionnait parfaitement hier
Puis hier soir impossible de caster j'ai tout tenter hier soir je m'y colle a nouveau aujourd'hui sans succès je cherche mais impossible donc je suis les réponses qui pourrait vous être donné 😞
EFx
Ok, same here. I was getting frustrated that "help" was being spectacularly not "fit for purpose"  as I was getting nowhere and every time I followed the "help" I was getting the "couldn't authenticate" error message. Grr!  Glad it isn't just me. Sad that  others are also frustrated and that "help" can't actually acknowledge there is an issue that they should have picked up on and resolved by now.
Mine did the same two hours ago. I was rebooting and trying evening. But not success. I dont know why. The device says as authentication failed.
Kghost
Same authentication failed message
