GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,152 REPLIES 16,152
zira360
My Chromecast is still not working and I tried to update it but I can't find any update on the TV to update my Chromecast because when it started in march 9th I did press the reset button and I tried to reconnect it but I didn't know it was a system problem so I'm having trouble connecting my phone to my Chromecast if there's any other issue please let me know as soon as possible thank you
WahLee
I still only see 3.30.1.5 on the playstore. How can I get 3.30.1.6?
Anapaulacorbell
Tem matérias dizendo que o erro com o cromocast já foi resolvido estou tentando der instalar o meu é não consigo, preciso de ajuda
Nath3
La version 3.30.1.6 de Google home n'est pas disponible dans le Play Store !
Jory1
Mine is still not working at all. I did the factory reset the day that happened because i though it was the problem. Today i tried to conect but had the same message issue asking me to contact you. Please help because its been more than a week without it
neokammmmmmmmmm
The post sent on the 17th and today 19th and the new Google Home version is still not avvailble on the app store or play store
Anonymous
Not applicable
E nada de funcionar
lita5
Boa tarde,
Não consigo gerenciar as minhas rotinas, informa que no idioma utilizado esta função não se encontra disponível.
Já reiniciei ambos os equipamentos, já verifiquei que o google home está actualizado, já adicionei o idioma ingles US e não consigo, conseguem ajudar?
lidiar
Seguindo orientações de vários blogs de tecnologia, consegui restaurar meus aparelhos Google Chromecast de 2ª Geração, retrocedendo manualmente a data do meu celular, porque como eu não sabia o que estava acontecendo e redefini os aparelhos. Mas retrocedi manualmente a data do celular ao dia 06/03/2025, e finalmente o celular conseguiu fazer contato com o Chromecast, reconfigurei a rede de internet, e a atualização baixou automaticamente. E finalmente consegui voltar a ter acesso ao Chromecast. Deu certo e o Chromecast voltou a funcionar.
James123455
Why put out the update on here saying update your app if the app isn't available yet. Joke
afhuyt201
When issue happened 1 week ago, I factory reset chromecast few times but no luck then I delete device from google home. Now I am trying to add device back in google home without any luck (could not setup device). Please help.
J1103
Datum op uw smartphone naar 8/3 instellen. Dan u chromecast volledig opnieuw installeren zowel Google Home. CHROMECAST zal terug geverifieerd worden. Datum terug naar huidige datum veranderen. Rustig wachten tot hij volledig geupdate is terug. Kan snel maar ook een dag duren de update. Chromecast zal terug werken als nieuw
Belgium
PazMoral
Hola, tengo la aplicación actualizada a la última versión disponible según google apps, 3.30.1.5 y no me reconoce el dispositivo. Lo reinicié de fábrica porque así lo indican ustedes en sus soluciones... necesito ayuda por favor para poder usar mi chromecast. Cuando intento conectarlo me indica "no se puede establecer comunicación con su chromecast"
msing002
Is there an ETA on the release date for the 3.30.1.6 for Android app version? Google Play does not have that version out yet
Aeolos
My Chromecast with Google TV has this firmware number 3.72.446070.
Since the latest update I can't listen to anything, no sound, nothing comes out of my TV when I try to watch anything through my Chromecast. Nor through Twitch, YouTube, Netflix, CrunchyRoll... no sound at all.
Please fix this problem, I haven't been able to use my Chromecast since the latest update.
AlbertoS
It didn't work
Insiste.
Yo lo tenía reseteado.
Primero cambié la fecha de mi tlf al 04 de marzo 2025. ( cualquier fecha anterior a la desconexion vale ).
Luego desde Google home lo volví a configurar.  Me daba error y le di a reintentar varias veces hasta que finalicé la configuración.  Volví a poner el tlf con la fecha actual.
Solo reproducía Fotos automáticamente.  Lo dejé conectado y se actualizó solo. No fue inmediato. Tardó , en mi caso, un día completo hasta que realizó sólo la actualización.
Ahora funciona bien, aunque diferente de como lo hacía antes.
Espero te ayude.
Vaishali29
Kindly solve it asap
Simple
Just change date to 1st March 2025 in your phone/iphone/tab and then connect to Chromecast.it will update your Chromecast then you will be able to connect wifi in your Chromecast then you will be able to use your Chromecast.
Fahadii024
Cirleide
Eu estarei de fábrica e não consigo conquistar mas o meu Chrome crash
AlbertoS
Now it works. If you have IOS after the upgrade of the google home, you have to go to the app settings and active access to Local Network.
En español:
Si tenes Iphone, después de actualizar tenes que entrar a la configuracion de la app y activar la opcion de acceso a red local (se desactiva con la actualización).
Anaa
It worked! I'm so glad it's back! 😁
Marcia5000
Si, como la mayoría reseteó a fábrica....
En configuración del celular cambien la fecha del teléfono a una anterior al 8 de marzo.
Ingresen a Google Home e intenten agregar el dispositivo.
Tardará un ratito, ya que tiene que actualizarse, pero finalmente con éxito, tendrán nuevamente el Chromecast operativo.
Una vez activo, actualicen la fecha de celular.
TYROD
maraming salamat sa pagpost nito.  Limang beses na akong nakikipag-usap sa Google sa telepono.  walang tulong.  nagpadala sila sa akin ng email at gusto ng serial number sa parehong device ko, ang serial number mate at modelo ng router ko.  kailan ito nangyari?  anong mga mensahe ang nakukuha ko kay yada yada yada at ang kailangan lang nilang gawin ay sabihin sa akin na baguhin ang petsa, i-set up ito at pagkatapos ay i-reset ang petsa pabalik at tapusin ang pag-set up at ito ay gumana.  salamat salamat salamat!
JoyK
Thanks Google! It's finally working
KitoTheFirst
Version on the playstore is still on 3.30.1.5
Smurugesan
How do I upgrade my home app from 3.30.1.5 to 3.30.1.6 ? Play store doesn't have the latest version of home app. Please advice.
Heyheyheyzee
Still cannot stream Apple Music or Spotify to Chromecast audio
paupombo
I updated google home and I tried to set up the internet chromcast configuration (I reboot the system before the comunication to avoid rebooting was sent)
I am now able to get to my wifi network but it does not connect (tried using the password from my defice and seting up the password manually)
Is this part of what is expected and still there is some update to be done contemplated on the device roll out you mentioned previously?
Karensy
I've been having this problem for over a week, how much longer will I have to wait?
Lillie45
Le problème était résolu mais aujourd'hui de nouveau plus rien ne fonctionne !
Shicco
I factory reset my chromecast (2gen) a week ago and since then I was not able to connect with it. Today,  I followed a lead  in this community to set the date on my android mobile to March 6, which I did. Then factory reseted the chromecast again and once it returned and presented the instruction to set it, I started Google Home on the mobile and went from there; it took several minutes as the mobile was probably downloading some software to the chromecast; then the Chromecast rebooted and updated itself and I was able to associate it again to my house. It soon started to show the Google screen savers and I was able to redirect Prime to the chromecast. So, I am fine now.
ejmata305
Still no solution to my google devices not responding. It might be a sign to ditch Google.
ejmata305
None of my Google pods are working correctly. Why is so complicated to get a reply from Google?
Faizi
Please tell me how to fix chrome cast . Chrome cast show "Could Not Communitate with your chrome cast" please tell me how to fix this problem please please please please please please please please
Buckey98
Still having trouble  even after the update
Insiste.
Espero te ayude.
Sallucy4
This isn’t working for me. Keep getting this :: Bedroom TV may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your iPhone’s privacy settings. Then try again.::
Sallucy4
I keep getting this message… -: Bedroom TV may be set up, but we could not communicate with it from your iPhone. Make sure that you have enabled local network access in your iPhone’s privacy settings. Then try again.:-
Matjeux
Did they give up?!
