GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,138 REPLIES 16,138
WuSi
It is almost the standard procedure to reset the device especially the Google help for problem solving also suggest trying to reset your device.
emilio11
e quello che dico anch io
Babbatool
Day two of not being able to listen to music at home 😢
as871026
一樣問題+1 但已還原。。。
LP1979
Please advise if there is a fix for my Chromecast as I reset the device and now it's not authenticating still.  This fix needs to be done ASAP.
Puurtaja
Turn back date on your phone to 8th of march and you can add chromecast back to your home. Still cannot cast or anything but then you can sit tight and wait for fix 🫤
nikhilagarwal
How much more time would it take? Do we have an SLA for this service?
GrowingTadpole
Hearing nothing from ya? I am back to HDMI cable...
PHorne
To late to say Do Not Factory Reset. Please advise.
Puurtaja
Umesh1
How will we come to know when the issue is resolved ? Will you send email or we have to check it manually
Chamika
The device has already been factory rest🤦‍♂️
paulw2201
Not good enough, Google! At the very least you should be providing updates more frequently. And I would love to know what you plan to do to compensate those affected. It's enough to make me want to switch to Apple!
firstclass
I factory reset everrtime this thing stops working.  what is the fix now??
BrunoRangel
Already factory reset
To late
NickLove
Where can I exchange for a new device that works?
LBN14
On what platform, will you provide the instructions  if I already made a factory reset?
The lake of official  information from Google on this,  is SOO bad !!!
BrunoRangel
Is there no way to revert the update that caused this problem?
Puurtaja
If you already made factory reset you can add chromecast bact to your home like this. Turn back date on your phone to 8th of march or earlier open google home and you can add chromecast back to your home. Still cannot cast or anything but then you can sit tight and wait for fix 🫤
Shambles
So do we just revert to this thread everyday until thw fix update comes out? How will we be notified of the solution otherwise?
Fackit
I've already reset my device. So what now?
CorBlimey
Will you - Google - please ensure you email us when the fix is ready, along with the instructions on how to deal with the matter if we have already done a factory reset. And could you please have the courtesy to update us very soon? Thanks
TwoSpaces
We are waiting.
Adro-
Any update it’s been over 24 hours
KPaks
Don’t fire the intern, please. (I’m the intern)
Lozzah
What is the estimated time frame for this issue to be fixed? It's not good enough to just say "as soon as possible" not once you're passed the 24 hour mark.
Also, I already factory reset my chromecasts because that's what I usually do when the glitch, not knowing there was a wider issue till it didn't work. So what do we do if we already factory reset?
dbajaj26
I am also suffering with this issue since yesterday morning. But solution till now. What to do? How to do?
No solution till now
Set the date on your smartphone back to march 7th. Then install your Chromecast through Google Home. It won't work for steaming anyway but it is connected to your net ready to receive the fix
トモヒコ
早くして下さい
トモヒコ
いつ頃解決するんですか?
dbajaj26
Please provide me the solution as I already factory reset my chromecast and now it's not connecting to my tv.
gsottot
You're just aware but you do nothing. We ought to stop pouring money into American pockets.
Dianabol
How long does it take for you to fix this problem?
AshleighJM
How far away is a fix? We are coming up 36 hours now.
MJ18
Como sea verdad que lo habéis desconectado en remoto para obligarnos a comprar el nuevo dispositivo,  o podéis enfrentar a una demanda colectiva... ahí lo dejo...que vergüenza para Google,.NUNCA compraré vuestro nuevo dispositivo,  prefiero comprar una tv nueva ...y marca Samsung...
sap4001
What to do if you already factory reset the device ?
Tyfer1313
Consumers should be compensated for such an issue impacting their services. Not only have we paid for the Chromecast, but we pay for multiple streaming services which we can no longer access as a result of Google's error and/or neglect of a customer population. This all seems very suspicious, how can anyone rely Google after such a disaster?!
Do better Google! 😕
dbajaj26
Please provide me the solution for this. As I already factory reset my chromecast device and now it's not configuring with my TV.
