GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,123 REPLIES 16,123
Any update on this. still cant cast anything to my tv. I knew i should never do updates it always screws something up. currently in recovery from a operation, worse time it could happen, when is this going to be fixed. How long intil you pay for my subscriptions as im unable to use them.
Grazie per le informazioni anche se si è faticato per venirne a conoscenza. Confidiamo nella bontà del Vostro intervento, buon lavoro.
Mire yo son eso no puedo ver la tele ni tengo antena ni puedo ver nada hace días necesito ayuda urgente no puedo esperar más
we are waiting for a solution !!!! Incredible !!!
WHAT THE HELLL!!!!!!! THIS IS A MAJOR **bleep** UP!
Hi and thank you for helping me with this situation! My Email is #, PLEASE KEEP ME POSTED 🙏Thank you!!!
Will there be an email coming out once fixed? I am one of the many who followed all the instructions on your site - including factory reset. Thanks
Dizer que já está trabalhando, sem diz um prazo ficar muito fácil!!! Que transtorno para nós usuários...
Salutare. Pentru cei care ați resetat cromecast exista o soluție pentru reinstalare. Intrati in setările telefonului, și dezactivați ora automata și fusul orar, setați ora manual sa fie sub data de 08.03.2025 rsetati aparatul și instalați înapoi. Dar tot nu o sa merga pima rezolva cei de la google. Cind dau sa proiectez yutube primesc un mesaj....Firmware-ul
învechit al dispozitivului
ar putea fi cauza. Aștepta rezolvarea Firmware-ul de cei de la Google
I didn’t found this forum earlier and reseted the chromecast. Is that bad?
Anonymous
Not applicable
I did it like five times... I think it's gonna be alright when we can cast again. Don't worry
No , I did it and found a forum which provided a way to add it back to google home .  You can search as well 😉
For **bleep** sakes
Afortunadamente para los dispositivos android hay una solución que he visto en varios post, pero para IOs? Alguna solución transitoria por favor?
lo cierto es que esto es intolerable, jamás volveré a comprar un producto de Google
Hola! Tiempo estimado de solución?
@GoogleNestTeam escreveu:
Olá a todos,
Uma atualização sobre a situação: a equipe identificou a causa do problema que afeta os dispositivos Chromecast (2ª geração) e Chromecast Audio.
Não restaure as configurações de fábrica do seu dispositivo. Se você já realizou uma redefinição de fábrica durante a solução de problemas, talvez também esteja enfrentando um problema em que não consegue reconfigurar seu dispositivo. A equipe também identificou a causa disso e está trabalhando em uma correção.
Estamos trabalhando para resolver isso o mais rápido possível e manteremos você atualizado quando houver mais para compartilhar.
Pedimos sinceras desculpas pelo inconveniente e agradecemos sua paciência enquanto isso.
Obrigado.
Estava aqui tentando de tudo para restabelecer agora que vi essa mensagem
Still can’t cast
Perdón, pero lo restaure! El consejo llego 24 hs tarde. Como lo van a solucionar para los que reservamos? Ese era el consejo de siempre.
Quise decir reseteamos
Hola
Por no encontrar respuesta, lo reset de fabrica.
Por favor indicarme como continuar.
Saludos
Thankyou, but can you please tell me when it will be fixed?
What did you say?
When will you finish your fix.
Como deberé hacer? en el momento que dejó de funcionar lo restauré de fábrica para tratar de solucionarlo, ahora no podré usarlo más?
Can you provide a window of time this issue will be resolved please?
Por favor está demás opinar, es evidente nuestro malestar. Por favor resuelvan el problema de forma oportuna.
Gracias.
Any update on the issue?
What happens if I did a factory reset in accordance with your connection issue instructions. I tried to contact customer service but the promised phone call never came.
Thank. I'am waiting for instruction.
Im making a comment so ill receive notification when this is resolved but i had already factory reset my device.
I have already factory reset my device , what can I do now ?
Anonymous
Not applicable
Just set the date back on your phone or whatever device you use to setup Google home
Set the date to March 7 or before. Then use google home to set the chromcast back up, it will then be connected to the internet, most likely will not be working but it will be ready for google IF the push a fix. Then feel free to reset the date back to today once the chrome cast is connected to wifi, and wait for google
Thank you JerryK it work good as you say , now waitting for google for a fix
Patience is wearing thin. This happened on Sunday. How long will it take? Do we get any credit for this?
Bastante tarde sugieren no resetear a valores de fábrica, lo hice el mismo día que comenzaron los problemas, porque como muchos pensé que era mi dispositivo y seguí las instrucciones que uds mismo tienen publicado en soporte,
Any fix yet? And what do we do if we did a factory reset?
Ainda não corrigiram essas atualização? Já estamos a dias sem poder usar um aparelho que custou caro.
This has been going on for days now; either Google wants to sunset the original Chromecast devices, or they are not competent to fix the issue.
Tired of waiting ordered this from Amazon to take Google out of the equation: https://www.amazon.com/dp/B0D6R3XT17?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
When will this be fixed please?
Yep. Step 1 in troubleshooting is turn it off and back on. When that doesn't work, factory reset. I guess I'm in that camp so I'll need the instructions for someone who factory reset their device.
