GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,152 REPLIES 16,152
Zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz.......................................
Muy mal Google 2da generación no funciona desde Chile.
Oh, ok, î’ll wait then.
Hey Google team, is there any updated??? It's been four days since the issue arised and none solution up to now. We as customers must have explanations!
Still working on solving the issue? Maybe use google search engine to find the solution 😂
I have already factory reset my chromecast, what do I do?
Any update as at 13Mar...unable to use my TV due to his or cast my PC. Appreciate if an update is provided
Merci
J'attends votre réponse pour la résolution de ce problème. J'ai déjà réinitialisé le Chromecast.
Merci
Cr4p. I reset my device.
Change your phone's date to 3/8, the re set it up.
That fix worked a couple of days ago, but today my CC2 went back to being a brick.
Anonymous
Not applicable
I am in Spain, when you consider to send the fix firmware to solve the chromecast problem?
how will I know when the problem is fixed?will you email me
Any specifics how the problem manifests itself? So users would know whether or not they experiencing this problem or something else? For example,  in my case the YouTube app was forcefully signed out and now the account sign in selection choice just freezes. Is this related to the issue you've identified?
Let us know when it's working again !
Any updates please
Cemil
Ya van varios días y todavía no hay novedades. Cuánto tiempo más hay que esperar??
J'ai réinitialiser, je ne savais pas. Rien ne marche.
Any updates on the resolving issue progress?
Its ok but I dont receive any solution so whats going to happen?
Any updates?
Is it confirmed that the factory reseted Chromecast (which was a logic first thing to do) is bricked?
It's easy to hack don't panic
Anonymous
Not applicable
no not bricked, how about set the date manually on your phone to March 7
Then use google home to setup the device again, it will then connect to the wifi network and be online just in case google pushes a fix. Once the device is on the wifi network, return your phone back to current date and sit back and wait for google to release a fix
That no longer works. If you actually had a Chromecast 2, you'd know that to be the case.
I can confirm that that is the case with mine. I don't think there will be much difference with mine and the thousands of others still out there. They will all have the same revoked certificate.
Soy de argentina y no puedo usar el Chromecast, por qué?
Can this error be fixed by me
This is not funny, I’ve not been able to use my chromecast in 6 days!!! Nothing works!!
Dejen de jugar con nuestra paciencia! Pongan las cartas en la mesa y salgan a decir que es a propósito para que tengamos que comprar un dispositivo nuevo! Están jugando con la ilusión de gente que no tiene la posibilidad de cambiar de televisor ni de dispositivo cada dos años como a ustedes les gusta!! Al menos sean serios y digan la realidad
Literally how is this not fixed yet
Anonymous
Not applicable
So it's Thursday and no update or fix for 2 more days..?!
Sigue sin funcionar
Anonymous
Not applicable
Your reaction was as late as his solution. The first thing a user does when he encounters a bug like this is to restart all computers. And since Google didn’t notice anything, it made me think of a later problem for doing so. I want to know how you will solve it, since I have three chromecast out of service thanks to you.
Everyone who has reset their devices should take the time to read the entire post.  If you actually do that you will see they are working out a fix for if you have already reset your device.  I think many people are seeing the bold "Please do not factory reset your device." and then stop reading.
The relevant part of the OP is:
"If you previously performed a factory reset during troubleshooting, you may also be experiencing an issue where you're unable to re-setup your device. The team has identified the cause for this as well and is currently working on a fix."
Please do not panic and keep a hold of your devices for now.
Hi Google,
It's Thursday in the meantime and it has been 4 full days now since my (and all, apparently)  2 Chromecasts (2nd gen) stopped working.
  • Any update on the situation ?
  • Any projected timeline ?
  • How will you communicate this to Chromecast users? Are we really expected to come and check here 4 times per day and search the internet for any updates on tech fora?
Thanks in advance for enlightening me and no doubt many many other Google customers.
Jan
This is taking too long. just send me a coupon for a new one please.
You know it's already friday, right? FRIDAY. You know, don't you? And my Chromecast is still a piece of useless **bleep**. Friday, five days later. F-I-V-E. Count with me: 1... 2... 3... 4... **bleep**ING FIVE DAYS.
