Remote control for Chromecast tv
JakubZekalo
Suddenly the buttons "HOME" "Back" "Enter" and cursors work in the remote control. It only works On/Off and voice assistant. What can I do to make all buttons work again?
Jeran
Hey there JakubZekalo,
I apologize for the late response, and thank you for being patient! Were you able to fix that remote issue? If not, I'd be happy to help you out. For this, you may need to check the remote settings on your Chromecast. To access them, open the Google Home app and select your Chromecast from the list of devices. Then, tap the Settings icon in the top right corner of the screen and select Remotes & accessories. You'll see a list of all the remotes that are currently paired with your Chromecast. To view the settings for a particular remote, tap on it in the list. In this case, select the option Learn remote buttons to reprogram those buttons.
Jeran
Muddi
How was your device? If you have additional questions or concerns about your device, please do not hesitate to update the thread, and we're glad to help.
Muddi
Jeran
Hey JakubZekalo,
Do you have any more questions? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
