02-25-2023 08:28 AM
I am trying to re-pair my Google TV after a move. I did a hard factory reset on the Google TV (held the button on the device). Now the screen is asking me to hold the left arrow and home button to pair the remote, but it won’t register. The solid light is on on the remote. From searches, it seems this means the remote is stuck in update mode. I’ve let it sit for an hour hoping it would cycle through, but no luck. I can’t use my phone to pair as other posts have suggested because this device isn’t paired to my new home’s Wi_Fi network yet. Any suggestions?
03-01-2023 03:00 PM
Hi Alex - that worked! Thank you so much for your help!
03-01-2023 12:20 PM
Hey Cschuma2,
Thanks for reaching out — let me help you out.
A few questions: are you still using the original battery? If so, try using a new one but make sure it's not a lithium-ion or any other batteries with rated voltage above 1.5 V. Try resetting your Voice Remote using the steps below:
Let us know how it goes.
Alex
03-01-2023 03:00 PM
03-01-2023 03:30 PM
Hi Cschuma2!
Awesome! I'm happy to hear that we were able to get this resolved! Let me know if you have other questions or concerns otherwise, we'll lock this thread after 24 hours.
Alex
