Wifi issue
osiris
In general the updates last year  improved wifi connectivity a lot. But still no connect with channels 149 and above. Will there be a fix or it is a hardware problem?
Azarco
Hi osiris,
We hope you were able to get the help you need but if you're still having trouble, you might want to check out this link. If the issue persists, feel free to submit another post and provide as many details as possible so that others can lend a hand. Hope this helps!
Kind regards,
Alex
