battery cover
mfowler809
My battery cover will not open? What is best way to slide it or open the cover to install batteries?
JenniferV
Hello mfowler809,
Thanks for reaching out. You might feel it's hard to remove the battery cover — this design is intentional. However, if you can't remove the cover when you slide it forcefully, try the following steps below:
  1. Stick one end of a cellophane tape to the bottom of the back of the Chromecast Voice Remote. Use the other end of the cellophane tape as a pull tab.
  2. Pull the end of the cellophane tape as you press the circular dented surface firmly.
I hope that helps.
Jennifer
JenniferV
How's it going? Do you still need help?
Jennifer
Jeran
Hey mfowler809,
Do you have any more questions? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
