09-23-2023 10:32 AM
Another Nest doorbell connection issue.
Purchased a Nest battery doorbell a few weeks ago and just got round to setting it up
Can't get it to connect to Google Home. Tried all the suggestions in previous posts -
Reinstall Home
Create new home network
Factory reset doorbell
Reboot of router
Nothing seems to work.
Any other suggestions before it gets returned to the shop and I try another make
Thanks
09-23-2023 12:32 PM
What exactly happens when you go to the Google Home app, and select adding a device, and select doorbell as the device you want to add?
Are Google Nest's instructions helpful?
09-23-2023 01:58 PM
It's not connecting through Google Home. Just getting a msg to make sure phone and doorbell are in close proximity. Tries to add the doorbell to the home network but fails.
09-23-2023 02:45 PM
You could try this troubleshooting topic:
https://support.google.com/googlenest/answer/9240048
Or try contacting Support using the link and instructions in this post:
09-26-2023 03:20 PM
@dbroon, thanks for reaching out. I just want to check if you managed to see the response above. Were you able to visit the links provided above? Did you try some troubleshooting steps there, or did you contact our support team? Please let us know how it goes.
I appreciate the input, @MplsCustomer.
