Battery camera won't connect to new google router system
ASEnvironmental
I recently purchased the google router with a wireless point system along with a couple of battery cameras.  I was able to connect the cameras to my wifi but it would only connect to the router, not the point closer to the cameras.
After some troubleshooting, it was determined the point had an internal issue and I needed to exchange and router with a new one.  I brought the new google wifi system and when I try to connect the cameras it won't do so.  Even when I scan QR codes for each camera I can't find either of them.
Is this because I didn't disconnect them or do a factory reset from the oil router system in the home app prior to using the new router components?
MH
I think I have the same problem...
Hey Folks.
