06-11-2022 03:47 PM
We got a Nest Cam (battery) for the garden a couple of months back and initially it was fine. Shortly after we got the external power supply for it and for the last couple of weeks it has run off that.
However, today when I asked the Google Nest Display to show the camera feed it told us the battery was too low. The camera was running off the mains, but also draining the battery as well. We took it off and put it on charge using the cable and plug in the box and it is charging very slowly, saying it will take 12 hours to charge and telling us to use the proper charger and cable.
So would this suggest the product has a faulty battery?
06-11-2022 06:29 PM
@Anonymous
I think you might have a faulty battery, faulty camera, or faulty power cable. We've had a Google Nest Camera (Battery) since Sept. 2021, plugged in at all times with the optional 10-meter power cable. The camera is always "Live" and if I turn off the power for the camera (it's on a switched circuit outside) to check the battery level, it's always between 87% and 100%. This was true during cold weather down to -20 degrees Fahrenheit this winter.
You could try contacting Google Nest Support at: https://support.google.com/googlenest/gethelp?hl=en
06-18-2022 09:43 PM
I appreciate the help @MplsCustomer. Have you reached out to our Google Support team about this? Also, have you experienced extreme weather conditions in your area?
Steve
06-22-2022 06:02 PM
Checking in to see if you have further concerns about your Nest Cam (battery)? Feel free to update this thread, and we're happy to assist you further.
Steve
06-23-2022 10:08 PM
Appreciate the help, Steve. Just checking in to make sure that you've seen our responses. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Archie
