Battery replacement
Psl5065
The battery on one of my nest cam outdoor/indoor battery cameras will only hold a charge for a short period of time. Can the rechargeable battery be replaced?
@Psl5065
The battery on the battery camera is not replaceable; in fact, there is no way to service the camera.
Perhaps you should contact Support to see if they'll replace the camera. We've had a battery camera since Sept. 2021, plugged in with the optional power cable, and it's online and "Live" all the time.
To contact Support:
