Camera not working
Pmilne
My indoor nest camera (2nd gen) doesn't connect and when you unplug then plug back in the white light pulses a few times then goes off.
It had worked and we unplugged for a while. I've tried a different plug and in a different socket and same thing.
Its an expensive item and frustrating it does work anymore.
@Pmilne
You could try a factory reset. The instructions are here, after the "Restart" instructions. You have to press the reset button for at least 12 seconds.
https://support.google.com/googlenest/answer/9252162?hl=en&sjid=8885676780986213284-NC#zippy=%2Cnest...
Then you could try reinstalling it in the Google Home app.
tajennifer
Thanks for posting. @MplsCustomer thanks so much for helping out by sending information about the Indoor Nest Camera (2nd Gen). That's definitely helpful for the community! @Pmilne I'm sorry to hear that your Nest Indoor Camera (2nd Gen) is not connecting. I understand how frustrating that situation can be. But don't worry. I hope the article you found was helpful in answering your about the Nest Camera not connecting.
Please let me know if you have any other questions, I'll be more than happy to help.
Jenny
Doesn't seem to have a reset button. White Light comes on then goes out. Then nothing. Very frustrating
@Pmilne
The reset hole on the battery camera and floodlight camera is on the bottom of the camera. On the 2nd gen indoor camera it is on the bottom of the camera head between the power cord and the camera head.
See the factory reset instructions link I posted earlier; unless your camera is defective, you may be getting a white light that goes out because you are "restarting" the camera rather than holding down the reset pin for at least 12 seconds for a "factory reset".
If you can't get it to work, you could try contacting Support:
