12-30-2021 04:14 PM
Unable to get back online . I was able to set the doorbell up in google home. Tested camera everything was fine. I waited to get someone to install it 2 days later now offline/ no wi no recognizing the device at all
12-30-2021 06:13 PM
i have the same annoying problem!! ughhhh
12-30-2021 06:24 PM
Update . I did a factory reset u have to stick a pin in the hole in the back until the light blinks yellow and reboots. I was able to
connect and Im up and running
03-01-2022 12:42 PM
03-04-2022 01:14 PM
03-07-2022 01:24 PM
Hey Folks.
12-30-2021 06:50 PM
I have multiple cameras that I cannot get back online after my internet went out this morning. All cameras work off of google points, which is plugged into back of router
01-28-2022 02:57 PM
Been trying for two weeks to get cameras back online after initial install. Done the reset button, read multiple links, but not close to fixing. ALSO, how do I assign and ensure the wifi link is connected.
02-27-2022 10:06 PM
I been offline for two weeks and nothing, I am frustrated because I have tried everything I found to do the troubleshooting and nothing has help
