09-05-2021 10:59 AM
The camera is saying it’s offline! We are getting a connection error, the entire system is not functioning.
09-15-2021 07:11 PM
I am literally having this same exact issue currently. Nest hello doorbell (wired)
1.)I upgraded my wifi to 1200 mbps and got a new modem.
2.) I did a factory reset on the device
3.) Changed the wifi server username and password.
4.) My technician who installed it from ontech said “sounds like a power transformer issue to me.” If this works then good but if not then I’m returning it and getting something else, I need 247 security i’m thinking of getting ring or Vivint not sure yet. Let me know what happens man thanks.
09-17-2021 11:03 AM
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I am terribly sorry to hear that you have had such a hard time with this! I would love to look into this issue further and help find a solution for you. I have some questions I’d like to ask you first:
Do you still need help with this issue?
What troubleshooting steps have you done thus far?
Have you tried to restart your device?
10-04-2021 05:02 AM
Ok I have the same issue. I have a camera that is several years old. It suddenly went offline the other day and will not reconnect. All my other wifi devices are working fine. This is what I've done. I unplugged if for a day and then plugged it back in. I tried to restart it, I deleted the app and reinstalled it, I deleted the camera from the app and reinstalled it as a new device. No luck. Only things I haven't done is a factory reset and change over from the old nest app to the new Google Nest app. What i want to know is the camera defective. I want to confirm that before I drop 180 bucks on a new camera.
10-11-2021 07:49 PM
My camera goes offline regularly and I cannot connect it today. I keep getting "Something went wrong" response. This happened the day after I signed up to continue Nest Aware, I also bought 2 Smoke and Carbon Monoxide detectors but I guess I should return those since I doubt they will work.
11-12-2021 08:38 AM
Hey Folks.
