Camera on night vision 24-7
Ediceman
Camera on night vision during the day. Tried turning it off. No luck. Other cams are fine.thx
14 REPLIES 14
EmersonB
Hello Ediceman,
Thanks for posting here in the Community and for sharing with us what you've done regarding your issue. When night vision is set to Auto, Nest cameras will wait to switch between normal and night modes only when the light gradually changes. For instance, at dusk or dawn, when the lighting is marginal. Some cameras will flip back and forth between normal and night modes, making the video too light or too dark. Hit this link for more information.
Yeah I know. This camera is stuck on night vision. Can't turn it off in the day. Tried everything.
EmersonB
Hi Ediceman,
Thanks for getting back to us. If possible, try moving it to a different position or restart it. In case you're still getting the same issue, we would recommend you to reset it to the factory default. Remember that after the reset all of your recorded videos will be deleted as well.
Keep us posted.
Ediceman
It's stuck on night vision. Nothing works. Camera must be going bad
@Ediceman
How long have you had your camera for? Is this a new concern you have been seeing? Do you have any other large light sources in the room with the camera? Please let me know.
Ediceman
camera is maybe 4 years old. Is outside aiming at driveway where it's always been. Started doing this a couple months ago.
@Ediceman
Thank you for your clarification. I know that there was a recent update that went out to the Google Home app. Have you been able to update your app and test to see if this is working after a restart? Please let me know.
janthadeus
Checking in — I just wanted to make sure that you’ve seen Brad’s reply. Let us know if there’s anything else.
Thanks for the help, Emerson and Brad.
janthadeus
Yes saw the responses.  Is there a link for the Google home app update?
janthadeus
Hey Ediceman,
Thanks for getting back to us. You may check this article to get updates about the Google Home app.
janthadeus
Hello there,
Just checking in to make sure that you saw my response. I'll be locking this thread if I won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
janthadeus
How's it going? Still need our help?
