10-01-2022 02:02 AM
I have several cameras around the home, I can’t find a way to automatically turn on/off these cameras when set to home. This should be a basic feature. Is there a work around?
10-05-2022 11:39 PM - edited 10-05-2022 11:40 PM
Hi Tony821,
Thanks for reaching out. I’m afraid this feature isn’t available. Turn off automatic switching for your camera if you use a schedule. If you use a schedule and automatic switching at the same time, your camera may not work correctly and can turn off and on unexpectedly. Use one or the other, but never both at the same time.
Depending on which app you use to manage your cameras, automatic switching can be turned off with Home/Away Assist (Nest app) or with Home & Away routines (Home app). If you’re not sure which one you used, check both.
Important: If you have other Nest products in your home, you can still set them to automatically switch when you leave or come home. You only need to turn off automatic switching for cameras using a schedule.
Let me know if that helps.
10-09-2022 07:06 PM
Checking in to see if you still need help with this. In case there are any follow-up questions or comments, feel free to update this thread and we're happy to assist you further.
10-11-2022 12:08 AM
I just wanted to jump in here to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
