03-23-2022 08:51 AM
03-23-2022 08:06 PM - edited 03-23-2022 11:17 PM
I ran into this issue earlier with (NEST CAM BATTERY) You need to scan the QR code that came with each camera or input the code manually ( Which can be found on the camera) when adding the new device. That fixed it for me. Simply remove the device and add it as a new device again. That is if you have your events set and it's still not recording. Hope that helps.
05-03-2022 12:32 PM
Check out this link for a complete guide on how to manage recording on your Nest cameras.
Hope this helps!
Kind regards,
Ryan
