07-24-2023 11:20 AM
I have 2 nest outdoor cameras that I bought in one package. I set one up and it worked fine. I waited to setup the second one and when I tried to set it up I can't get it to connect. I did a reset and started over. The first camera reset fine but when I went to setup the second camera I still couldn't get it to connect. What am I doing wrong?
07-24-2023 12:43 PM
In order to get any hints from other customers, it would help to know what exactly happens when it "can't connect". You say you waited to set up the second one; did you wait long enough that perhaps the battery needs to be charged first? And is the second camera farther from a Wi-Fi access point than the first one?
07-31-2023 04:22 PM
Hello everyone,
@swmpr, thanks for reaching out here in the Community. To know more about this issue, I’d like to confirm, what is the light status of your Nest Camera? Do you see any error messages? How did you perform the reset? Hit this link for more information about resetting your Nest Camera. Let us know your update here.
08-02-2023 06:06 PM
The light on the camera is white. I have tried to add the camera through Google Home and the Nest app. Everything goes fine until I get to the step where you plug the power cord into the camera. It says the camera will chime and the light will turn white. Then the light is supposed to turn blue and you should be able to connect. The light never turns blue and it won't connect to the app. I setup 1 camera several months ago and everything worked fine. I tried to add a second camera and kept having problems so I did a factory reset and now I can't get either on to setup. The error message I get is "Try moving closer to your nest cam (battery)."
08-02-2023 08:27 PM
08-03-2023 08:23 AM
Is Bluetooth enabled and turned on on your phone?
If it is, since you cannot even get the camera to a ready status (blue light) for the install and have tried a factory reset, perhaps you have a defective camera and should contact Support for a replacement, using the link and instructions in the post below:
08-03-2023 01:07 PM
Hi swmpr,
Thanks for posting in our Community. I’m sorry to hear that you’re having issues setting up your Nest camera. Let’s check it out.
Let´s factory reset the device. Follow the steps below:
Let me know how it goes.
I appreciate your help, Emerson, and MplsCustomer.
Lance
08-05-2023 11:05 AM
That worked. Thanks for your help.
08-06-2023 03:44 PM
Hey swmpr,
No worries. I’m glad to hear that the issue has been resolved. Reach out if you have any other questions in the future.
Lance
