06-23-2022 03:09 PM
I have a nest camera (battery) on my porch facing onto my path & the street. At low sensitivity it does not activate unless someone actually enter the front yard, which during the day is fine but I would like to increase sensitivity overnight to high (& video length to 3 minutes) then return to low sensitivity during the day. Is there anyway to do this automatically, it's a pain changing the settings twice a day.? I have tried setting up a routine but doesn't appear to be a setting that it can change.
06-29-2022 08:22 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I understand how frustrating your situation must be, and I would love to help however I can. You can also create custom Activity Zones to further reduce the amount of activity your camera detects. Use the app to draw an Activity Zone around a part of your camera's view, then select the event notifications you want to receive for that zone. Set up and use Activity Zones
07-02-2022 09:18 PM
I appreciate the help @Brad. Checking in to see if you have further concerns about your Nest Cam (battery)? Feel free to update this thread, and we're happy to assist you further.
Steve
07-03-2022 02:01 AM
I appreciate the help but this isn't actually a solution to the original problem of automating settings changes
07-05-2022 08:11 AM
07-06-2022 08:24 AM
Just checking in on this thread and the activity on it. We'll leave this topic open for another 24 hours in case there are any follow up questions or comments.
