06-10-2022 04:28 PM
My internet provider changed a modem for me to upgrade the system but now my google cameras, displays and speakers cannot connect to the new WIFI. Ho do I fix this?
06-10-2022 04:45 PM
The easiest approach, if you can do it, is to set the network name (SSID) and password on your new modem to the same values used on your old modem. Otherwise, you'll have to use the instructions on this Google Nest Help page; Google Nest does not make it easy: https://support.google.com/googlenest/answer/9223711?hl=en
06-13-2022 05:15 PM - edited 06-14-2022 05:17 PM
Hey Baynit,
Appreciate the help, MplsCustomer. I'm dropping by to ensure if everything is covered here. Hope that sheds some light on the issue.
Archie
06-14-2022 05:18 PM
Hey Baynit,
I wanted to follow up and see if you are still in need of any help? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Archie
06-15-2022 05:43 PM
Hey Baynit,
Archie
