10-22-2021 12:28 PM
Does this need to be wired to a switch, or is it okay to wire it to constant power?
10-22-2021 12:44 PM
It does not need to be on a switch , it would use constant power yes.
10-23-2021 10:17 AM
I installed mine where my existing floodlights are, and I leave the switch on. It was nice because all I had to do is flip the switch off to replace them, then turn it back on. I will probably leave the switch rather than cover it, just so I can flip them off (maybe during a bad storm) or for some reason, but they do not need a switch and you can directly hard wire them to constant power.
10-28-2021 10:33 AM
Hey, Boanarrow.
I just wanted to follow up real fast to see if you saw the replies here and if you were able to find the answer to your question here. If you need anything else, just let us know.
Thanks.
10-29-2021 12:24 PM
Hi, everyone.
Thanks
