10-23-2021 12:10 AM - edited 10-23-2021 10:51 AM
So i wanted to move in to the 21st century and install the best recommended video doorbell. Checked the compatibility website for the current chime transformer i had and was given the green light(between 12v and 16v).
When first connected, the ring light was orange, and replaced transformer to a new one with 24v eliminating the chime(as it’s 12v). Now the light was blue but after like 10seconds when on, a small green light(top of camera) flashes once and system turns off and back on after a couple of seconds. It repeats the same thing all over.
I tried to connect it to USB cable to the back and does the same. It lights up orange for a few seconds, then turns blue and after a few seconds green light at top flashes and turns off and repeats.
On both occasions while trying to connect to device i get error NC021. I tested new transformer with meter and is giving the right voltage.
What is wrong?? Defective product??
Edit: Tried to change to a new transformer again and still the same result
11-04-2021 11:39 AM
I apologize for my late response. Thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be. I just wanted to make sure that your issue is addressed.
11-07-2021 05:39 AM
I have the same problem. Doorbell has been working for years, I have moved house and reset the doorbell, when trying to re-add in the Nest app I get nc021, incorrect access code. I have scanned the QR code so it isnt incorrect. I have rebooted phone and doorbell and tried another phone, neither help.
11-23-2021 12:57 PM
11-24-2021 09:24 AM
Hey Folks.
