Door bell delaminating
TxAg95
My wired Nest Hello door bell cam is delaminating and it out of warranty.  Can I get a replacement?
JillG
I've seen others here in the community post about this issue. Unless the doorbell is under the warranty period, Nest doesn't seem to replace them. Couldn't hurt to contact them via chat or phone though.
Jill
I am so sorry to hear that your Nest Hello doorbell is peeling! I can imagine that has been quite frustrating to see. Unfortunately, because your device is out of warranty, it is not something that we will replace for you. My suggestion would be to check online, and see if you can purchase a used one, or you can pick up the Nest Doorbell (battery) as a replacement.
Hey Folks.
