Doorbell (Battery) locking pin stuck.
TOGgledShot
Hey Google,
Aside from taking a glue stick and trying to pop out the little locking pin (the little plastic pin that locks the doorbell to the mount on the back top middle of the device) like a dent in a cart door...
Is there a simpler, easier way to get that locking pin to stay out?
This seems like a design flaw since the opening to unlock it from the mount is on the top where dust and other particulates like to gather...
I've had the doorbell for about a month or so and I unhook it once to re-pair it to my network and now it won't lock to the mount.
Any help would be appreciated.
Thank you, 🙂
8 REPLIES 8
StuCun
I’ve had the exact same thing happen and it’s not easily fixed. Can barely figure out how to get this returned to the Google store… Finding return info it a nightmare
janthadeus
TOGgledShot, awesome! Good to hear that!
StuCun, could you also please also fill out the form so we can further assist you?
janthadeus
I'm sorry to know that your Nest Doorbell battery locking pin is stuck. Let's check this out — could you please fill out the form so we could further investigate?
I have submitted the requested form.
Done…
Yup, mines doing the exact same thing.  I can't even connect it partially just to get it to work for the time being.
Camera won't work if it's not clipped into the mount according to the Google Home app.
janthadeus
Hey folks!
We've received your form-- thanks for filling that out. Please keep an eye on your email as someone from our team will reach out to you to assist you further.
