Doorbell chime not working
Vannitz
I have installed my nest doorbell in properly and before I connected to the app, my doorbell chime was working but ever since I connected the doorbell to the app, the chime wasn’t sounding I was wondering on how to make it work?
@Vannitz
Well, you have to have the correct voltage on your doorbell's transformer (see https://support.google.com/googlenest/answer/9247132?hl=en), the Nest Connector has to be correctly wired to your chime (see https://support.google.com/googlenest/answer/9247327?hl=en and https://www.googlenestcommunity.com/t5/Cameras-and-Doorbells/Wiring-diagram/m-p/24455), "Indoor Chime" has to be turned on in Settings in the Google Nest app, and you may need to enable "Chime Duration" in Settings if you have an electronic chime.
lafarrell61
I had same problem and solved it by going to settings and turning on indoor chime and duration, then UPDATING WIFI.  They forgot to mention this step!
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Hey Folks.
