03-21-2022 11:11 AM
Add me to the list of those with this unacceptable design flaw and Google is not backing their product. At a minimum, Google should be providing a free cover. Mine is a little over the 1 year warranty period. I would have inquired sooner but I thought it was due to me forgetting to peel off one of those protective plastic pieces and it had baked in the sun. When I searched it out, I found how many others have the same result. Not cool.
03-21-2022 11:13 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
