01-02-2023 02:26 PM
Recently installed a Google Nest Doorbell (wired, Gen 2), and it will notify my phone, and show me live video, etc., but will not ring my indoor chime. I checked the transformer and it meets specifications (16 Volts and 10 VA). The hammer in the chime will move, but barely. My old doorbell rang the chime fine before installation of the Nest Doorbell. I am thinking it is not getting enough power, despite meeting minimum specifications.
Is there anyone with some insight on what might be the problem? Do I need to replace/upgrade the transformer, by chance? Concerns with that?
Thanks, -Tim
01-02-2023 04:42 PM
10VA is the minimum. When we added a second Nest Nello doorbell a couple of years ago, we upgraded to a 16V 30VA transformer.
01-30-2023 03:16 PM - edited 01-30-2023 03:16 PM
Well, installed a 16 volt, 30 VA transformer. That seems to have done the trick. Even though I met minimum specifications for what should have worked for this doorbell, it still needed a transformer upgrade.
01-02-2023 04:42 PM
01-06-2023 08:42 AM
Thanks for your help here, MplsCustomer.
Just checking in to see how the conversation is going. Please let us know if you have any further questions or concerns.
01-07-2023 07:44 AM
Hi Brad,
Yes, I do still need help. I don't have two Nest Hello Doorbells, like MplsCustomer does. I have one of what I described above, and I meet minimum specifications for adequate performance for that one doorbell. It should work properly. Yet my doorbell still will not ring my chime, the live video is intermittent, and notifications are sometimes very delayed. My mobile phone gets a good WiFi signal at the doorbell, so I'm not terribly concerned that it is my network. Why might my doorbell not be working correctly even with an adequately-powered transformer?
Thanks for checking in.
-Tim
01-11-2023 01:36 PM
If you are wondering if your device is faulty, or what your options are, please fill out this form, and a higher tier of support will reach out to you with next steps.
01-17-2023 12:18 PM
If my Nest doorbell is battery powered, can it ring on my phone and google speaker. I believe I have seen that it doesn't ring. That is a ridiculous outcome if that is the case. Is here any plan to update this functionality.
01-23-2023 10:59 AM
You definitely can receive notifications regarding a doorbell notification if you set up a smart display or speaker with your Nest Doorbell (battery). Please make sure that Visitor Announcements is enabled in your settings, and test your devices to make sure they are connected and working as intended. You can learn more here.
01-26-2023 11:00 AM
01-30-2023 09:53 AM
01-31-2023 08:57 AM
Glad to hear that your new transformer did the trick. As this looks to be resolved, we'll be locking and closing this thread. If you still need assistance with this issue, feel free to start a new thread. Thank you for your understanding.
