Doorbell
dhiren
I know six digit code is on back of nest video doorbell. Now, it is wall mounted. How do I get that code
Ashepherdson
The Google Nest Hello is designed to snap into the wall mount. You can simply remove the camera from its base using the included release tool or an unfolded paperclip. You may follow the steps below:
  1. Insert the tool into the hole on the bottom of your Nest Hello.
  2. Press upward until your Hello snaps off the base.
  3. Grip the bottom of your camera and pull it away from the wall and off the base.
Sorry for my late response. Thank you for all of your patience while waiting for a reply. I just wanted to make sure that your issue is addressed. I am terribly sorry to hear that you have had such a hard time with this! I would love to look into this issue further and help find a solution for you. First off, I have some questions I’d like to ask you.
  • Do you still need help with this issue?
  • What troubleshooting steps have you done thus far?
  • Have you tried to restart your device if you haven’t already?
  • If the restart didn’t work, have you tried to do a Factory Reset? This would be a last resort option, but would clear out issues and the device would essentially be ‘brand new’
GarrettDS
Have a great day.
Garrett DS
GarrettDS
Have a great day,
Garrett DS
