Existing door bell and cameras
Twest
Just purchased home that has Nest door bell, smoke det, cameras, and thermostats.
app will not let me add doorbell since is registers to old owner.  Is there a hard reset?
@Twest
The previous owner has to remove each Google Nest device from their Google Nest app or Google Home app while they are still on the Wi-Fi for the home.  After that, each device must be factory reset.  Only then can you re-install them.
https://support.google.com/googlenest/answer/11151047?hl=en#zippy=
janthadeus
Checking in — have you tried the suggested steps provided by MplsCustomer? If so, how did it go? Let me know if you need more help.
I appreciate your help here, MplsCustomer.
janthadeus
Hey Twest,
janthadeus
Just checking in to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
