Familiar face problem
Italiano
I have paid subscription. The doorbell refuses to see familiar face, it just states person.
I have done hard reset, removed from Google home and reinstalled but still cannot identify familiar face.
It use to work perfectly.
Help please
SaraEs
Hi @Italiano,
Thanks for reaching out to the community! I'm sorry to hear that your Nest Doorbell is not recognizing familiar faces. I appreciate your effort by trying to remove it from the Google Home app and also doing a hard reset; no worries, help’s here.
To isolate the issue, I’d like to ask a few questions:
  • What specific Nest Doorbell do you have?
  • How did you perform the hard reset? You can confirm the hard reset with the following steps:
    1. In the back part of the doorbell, you find a pinhole.
    2. Press and hold the pinhole until you hear one melody.
    3. Once you hear the first melody, please do not release; keep going.
    4. Keep pressing until you hear a second one; after that, release it.
    5. Just make sure that the light in the front part of the doorbell is blue and blinking; that means the doorbell did a correct hard reset.
  • When did the issue start?
  • Have you made sure the subscription is under the email address that you have in the Google Home App? To check your subscription, let’s try this:
    1. Go to your profile in the Google Home app.
    2. Tap on Home Settings.
    3. Tap on subscriptions:
    4. Tap on Google Home Premium and check if you have a current plan.
Please feel free to share any additional details you think might be relevant.
Sara
Italiano
Yes all that has been done. Nothing solved
SaraEs
Thanks for the follow-up information.
The team would like to learn more about this situation. When you get a chance, please fill out this form and let us know when you’re finished. We’ll have someone reach out to you via email from there.
Sara
