11-01-2021 03:56 PM
Installed new Floodlight camera and camera works fine, and lights come on just as advertised. Now trying to adjust brightness and the control says offline /not responding. How can that be? How do I get control over the brightness?
11-01-2021 06:10 PM
You’re not alone. Seemed to work out of the box then started getting glitchy. Mine went offline then disappeared from the app.
11-06-2021 03:21 PM
Same here. Works as advertised but the app does not.
11-30-2021 01:31 PM
I would suggest that you first try to restart your Nest Cam with Floodlight (wired) which you can learn how to do here. If not a restart, Factory Reset your camera and try to see if this fixes the issue first.
12-15-2021 03:19 PM
Have a great day.
Garrett DS
12-17-2021 02:45 PM
Hey 36WSB,
It looks like we haven't heard back from you so I'm going to go ahead and lock the thread. If you have any further questions or concerns, feel free to create a new thread.
Have a great day!
Eric
