Floodlights won’t turn off
sfo-riser21
I’ve seen similar posts but still can’t seem to solve this..my Nest Cam Outdoor Flooights won’t turn off even though there is no apparent motion.
I’ve turned off the option that turns on the floodlight when viewing from the App.
Any suggestions?
2 REPLIES 2
Restarting and factory resetting your Google Nest camera or doorbell will have different results:
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
Factory reset: Erases all your settings and options, and restores its factory default settings. It will not automatically reconnect to Wi-Fi and you'll need to set it up again.
You can find this information, plus additional information on this process here. Please let me know if you have further questions.
Ryan_G
Check out this link for a complete guide on how to manage your Nest camera through the app.
Hope this helps!
Kind regards,
Ryan
