06-29-2023 11:46 AM
I have 2 Google Nest 2nd Gen (indoor wired) Cams. One of them went offline. I use the Google Home app. I unplugged the camera for 30 seconds and plugged it back in and it was still offline so I removed it from the app and unplugged the camera for 30 seconds again and when I plugged it back in the white light came on but the blue light will not come on and thus I cannot re-add it to my Google Home app. I have gone as far as resetting my wifi, removing both cameras from Google Home, Deleting the "Home" I created, removing the app from my iPhone 12, readding, recreating the home, and adding the other camera (which had no issues) but this camera will still NOT show me the blue light. What should I do? I have had both of these cameras for over 6 months and haven't had any issues until now with just the one camera.
07-03-2023 01:57 PM
Hello mrsgarfoose,
Thanks for posting here in the Community. We appreciate you giving us the steps that you already took on your Nest Camera. To turn on the blue LED light on your Nest Camera, you need to factory reset it. Here is the link on how to factory reset your Nest camera.
Let me know if that works.
Edmond
07-03-2023 06:11 PM
I bought a brand new camera from the Google Store and it has the same behavior. The light is blinking yellow and it never makes it to the blue light. Is it bricked? Reset button doesn't do anything.
07-03-2023 06:24 PM
So I figured out that my camera came with a defective power brick. I used a different one and it got enough power.
07-04-2023 02:18 PM
Hey everyone,
@akorch, glad to hear you're able to fix it.Usually if the Nest Camera LED lights are yellow, it means it's not getting enough power and will not let you set it up on the app.
@mrsgarfoose, I just wanted to follow up and see if you still need any help. Let me know if you have any additional questions.
Edmond
07-06-2023 02:34 PM
Hello there,
Please let me know if you have other questions or concerns as I will be locking this after 24 hours. Feel free to start a new thread and we'll be happy to help.
Edmond
