01-28-2022 09:28 AM
Hi I went to install my nest doorbell after it being put away for a while and I seemed to have lost the wedge and the metal base mount. Can I get a replacement or something all the 3rd party ones require the back plate so it's hard for me to figure an alternative.
01-28-2022 09:42 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so we can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
